[postgis-users] Newbie: Windows Install Help
Tyler Mitchell TMitchell at lignum.com
Fri Jun 21 14:34:20 PDT 2002
I thought I might as well try too.  I can't get past ./configure for
postgresql.   I used your options Norman (from
http://postgis.refractions.net/pipermail/postgis-users/2001-June/000025.html)
but it bails on me complaining:
checking whether the C compiler (gcc -O2 ) works... no
configure: error: installation or configuration problem: C compiler cannot
creat
e executables.
Any suggestions?
                      "Norman Vine" <nhv at cape.com>
                      Sent by:                                To:       <postgis-users at postgis.refractions.net>
                      postgis-users-admin at postgis.refr        cc:       <jason at tishler.net>
                      actions.net                             Fax to:
                                                              Subject:  RE: [postgis-users] Newbie: Windows Install
                                                               Help
                      06/21/2002 02:09 PM
                      Please respond to postgis-users
rerun the cygwin setup program and make sure you have 'crypt'
package selected for download under the 'Libs' category and
try building again
Norman
>-----Original Message-----
>From: postgis-users-admin at postgis.refractions.net
>[mailto:postgis-users-admin at postgis.refractions.net]On Behalf Of
>Hankley, Chip
>Sent: Friday, June 21, 2002 4:46 PM
>To: 'Tyler Mitchell'; postgis-users at postgis.refractions.net
>Subject: RE: [postgis-users] Newbie: Windows Install Help
>Thanks Tyler... that got me a LITTLE farther! Still problems though.
>I followed Norman Vine's instructions from last year - see
>e/000025.html
>The last few lines of the output after I make (this is the make for
>PostgreSQL) show errors:
>/usr/lib/gcc-lib/i686-pc-cygwin/2.95.3-5/../../../../i686-pc-cy
>gwin/bin/ld:
>cannot find -lcrypt
>collect2: ld returned 1 exit status
>dllwrap: gcc exited with status 1
>make[1]: *** [array_iterator.dll] Error 1
>rm array_iterator.o
>make[1]: Leaving directory `/usr/src/postgresql-7.2.1-2/contrib/array'
>make: *** [all] Error 2
>The only error that I see is the "cannot find -lcrypt. Sure
>enuf, there's
>not a file or directory by that name in the
>i686-pc-cygwin/bin/ - is that
>what this means? Where can I get it? Are the instructions
>Norman provided
>still valid?
>TIA!
>Chip Hankley
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
