[postgis-users] Path finding
Luis Mota luis.mota at iscte.pt
Sun Jun 30 12:58:51 PDT 2002
Hi everyone.
I have to deal with a path finding problem.  The underlying data is
stored in postgis. It is a collection of LineStrings.
Since I have a AI backgound, I based the search on a classic A* search
algorithm, that is able to find the optimal path (even if this is not
vital to me). I programmed the algoritjm in Java and I access the DB
each time I have to know the lines that start at a given point.
This process is computationally very demanding... Because of this, the
algorithm takes a very long time to find any kind of path.
I think that the problem is that I am permanently querying the DB
through JDBC.... This must take a lot of time, I suppose.
Now I've been thinking that the best way to do this would be to make a
search algorithm directly in the DB. This way, the only thing I would
have to return through odbc would be the final answer and not thousands
of LineStrings.
Before moving forward to this, I would like to know if someone has any
experience/thoughts/hints about this. Maybe someone has already
implemented such a function...
Anyway, I'd like to know if you think that this is possible at all, or
what would be the easier way to tackle this problem...
Bye for now, Luís Mota
