[postgis-users] Question on transform.
Luis Mota luis.mota at iscte.pt
Wed Oct 2 15:55:35 PDT 2002
Hi everyone.
I've been using the transform function, but I have some surprising
results...
For instance, if I issue the following query:
select transform(geomfromtext('POINT(0 38)',4803),4326);
the result I get is:
       transform
 SRID=4326;POINT(38 0)
(1 row)
ie, exacly the same point... This is obviously wrong, since the two
GEOGCS's are different. For instance, the prime meridian is different..
Is it possible that I have some instalation problem? Was this a bug
corrected in a later version?
Thanks for any help.
Bye, Luís
