[postgis-users] Question on transform.
Paul Ramsey pramsey at refractions.net
Wed Oct 2 15:51:52 PDT 2002
Luis,
You can confirm on the proj4 mailing list (try this out using the proj4
commandline tools) but my understanding is that proj4 mostly ignores
geogcs transforms. There are a few exceptions to this rule, but it is
mostly true, since proj4 was originally written without any geogcs
transform support at all. The support which is there was retrofitted in
later by Frank Warmerdam.
Frank can correct me, of course... :)
Paul
Luis Mota wrote:
> Hi everyone.
> I've been using the transform function, but I have some surprising
> results...
> For instance, if I issue the following query:
> select transform(geomfromtext('POINT(0 38)',4803),4326);
> the result I get is:
>       transform      -----------------------
> SRID=4326;POINT(38 0)
> (1 row)
> ie, exacly the same point... This is obviously wrong, since the two
> GEOGCS's are different. For instance, the prime meridian is different..
> Is it possible that I have some instalation problem? Was this a bug
> corrected in a later version?
> Thanks for any help.
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
