[postgis-users] Question on transform.
Luis Mota luis.mota at iscte.pt
Wed Oct 2 16:15:53 PDT 2002
Hi.
As far as I know, I have proj4 installed... But it was a difficult
installation, therefore I'm not too sure... I think it is installed, since:
- I have a ' proj4text ' column on the spatial_ref_sys table and
- a query like select transform(geomfromtext('POINT(100000
150000)',20790),102165) results in POINT(699252.037333454
-120288.63384568). These are two PROJCS's.
Does this mean it is correctly installed? How can I verify this?
I would anyway like to ask the Proj4 people if this works... But I don't
know how their SW is being used by PostGIS... Is there a specific
function that you use? Which one? Or are the Proj4 people familiar to
PostGIS?
Thanks, bye, Luís
Andy Turk wrote:
>On Wednesday 02 October 2002 03:55 pm, Luis Mota wrote:
>>Hi everyone.
>>I've been using the transform function, but I have some surprising
>>results...
>>ie, exacly the same point... This is obviously wrong, since the two
>>GEOGCS's are different. For instance, the prime meridian is different..
>>Is it possible that I have some instalation problem? Was this a bug
>>corrected in a later version?
>>Thanks for any help.
>>Bye, Luís
>I had the same problem. Then I noticed that Proj.4 wasn't installed on that
>machine. Make sure that you've got Proj.4 installed and that its library is
>available to postgres.
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
