[postgis-users] Upgrade problem
Chris Hodgson chodgson at refractions.net
Mon Oct 21 10:10:09 PDT 2002
Do you get no error message at all? You should test using mapserver's
command-line shp2img (command line is generally more convenient and browsers
don't always show you the error message properly. If you still don't get an
error message, all I can do is recommend the newest mapserver (3.6) - and
get the mappostgis.c file out of mapserver's cvs as it  has WAY better error
reporting.
Chris
----- Original Message -----
To: <postgis-users at postgis.refractions.net>
Sent: Monday, October 21, 2002 7:17 AM
Subject: [postgis-users] Upgrade problem
> Hello all,
> I have upgraded from pgsql 7.1.3 to pgsql 7.2.3 and
> from postgis 0.5.1 to 0.7.3 ...
> I'm using mapserver 3.5 and after the upgrade process
> nothing seems to be working...
> when i start mapserver with postgis it returns a blank
> page insted the geometry draw...
> any ideia what could be wrong??
> Thanks
> João
> _______________________________________________________________________
> Yahoo! GeoCities
> Tudo para criar o seu site: ferramentas fáceis de usar, espaço de sobra e
acessórios.
> http://br.geocities.yahoo.com/
> postgis-users mailing list
