[postgis-users] Mapserver mail list?
Thomas, Cord cthomas at rand.org
Tue Oct 22 09:24:13 PDT 2002
I saw someone previously mention they cross-posted and it was a
mapserver-related topic - is there a mapserv list?  I tried signing up at
umn, but when i queried the lists, it only returned test - no mapserv list.
-----Original Message-----
Sent: Tuesday, October 22, 2002 9:22 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] configure error
Roland Forster writes:
> I tried the configure lines from Norman below but it doesn't work with
> too.
> What do the lines mean generated by config.log?
> Norman wrote: "Try building again after logging in as a user with
> privelige"
> How to do?? My postgres user is part of the administration group!
This should be OK it was hard to say from the error message
> configure:1377: gcc-2 -o conftest -O2   conftest.c -lcygipc 1>&5
> cannot find -lcygipc
you are getting further into the build process
You must have installed cygipc else Postgres wouldn't be running
but configure is failing because ld cannot find libcygipc.a
does  /usr/local/lib/libcygipc.a  exist ??
postgis-users mailing list
