[postgis-users] configure error
Roland Forster roland.forster at knuut.de
Wed Oct 23 08:06:30 PDT 2002
Thank you a lot Norman,
that's it !!
Roland
----- Original Message -----
To: <postgis-users at postgis.refractions.net>
Cc: <roland.forster at knuut.de>
Sent: Wednesday, October 23, 2002 1:38 PM
Subject: Re: [postgis-users] configure error
> Roland Forster writes:
> > the following i tried,
> > but doesn't work ...
> > > but the good news is that I managed to build todays PostGIS source
> > > with the following
> Roland
> I guess one of our mail clients changed the formatting
> and broke the script
> I have attached a slightly modified script this time
> Copy this into your top postgres source directory
> /usr/src/postgres-XXXX
> and execute it from there
>   % prep_postgis.sh
> Then cd into your postgis directory
>   % cd contrib/postgisXXXX
> and try making PostGIS
>   % make
> the XXXX's above reflect version numbers if any
> HTH
> Norman
