[postgis-users] Help updating SRID values...
Bill Wheaton gisgeek at nc.rr.com
Sat Feb 22 17:46:25 PST 2003
That was it.  Many thanks!
Bill
Paul Ramsey wrote:
For the last step, do not 'select into..'.
Instead, 'insert into yourtable select * from tmptable'
Bill Wheaton wrote:
> PostGISers:
> I have to change (update) the SRID in a geometry column. I've searched
> for methods of doing this and came across some posts from about a year
> ago...The procedure suggested by John Reid and Dave Blasby below seems
> to work EXCEPT for the last step...SELECT INTO only seems to allow you
> to create a NEW table not move records from one table to another. This
> is probably a simple postgreSQL question, but I'm a stumped newbie. The
> procedure I'm trying to follow is below. Again, I'm just trying to
> update the SRID for a geometry column (had a dumb typo when loading the
> data). If there is an easier way, I'd love to hear about it.
> Any help is greatly appreciated...
> Bill
> Alternatively, here's another method that should work for you:
> 1. Make a copy of your table (this will have no contraints on it):
> create table tmp_table as select * from <table>;
> 2. DropGeometryColumn() on your old table to de-register the geometry
> in
> the geometry_columns table
> 3. drop the old table
> 4. create the table again
> 5. AddGeometryColumn() to create & register the geometry column. Make
> sure you set the parameters correctly.
> 6. If you're changing SRIDs you'll have to:
> update table tmp_table set <geometry column> = setSRID(<geometry
> column>,<srid>)
> 7. use "select into..." to put the rows in tmp_table into the new table
        __
       | Paul Ramsey
       | Refractions Research
       | Email: pramsey at refractions.net
       | Phone: (250) 885-0632
       \_
