[postgis-users] Running createlang and postgis.sql
Robert W. Burgholzer rburghol at vt.edu
Tue Jun 3 09:42:24 PDT 2003
Mike,
I just had the same question today, thanks for posting it. It seems that all
is right with the data import and I have successfully added data, and
retrieved it via avpgcon. So, I would say, no, you needn't be concerned,
however, I am not the expert, thus all I say is speculation.
Perhaps this is a newer, more extensive error condition being reported by
postgresql, are you running postgresql 7.3.3?? (I am)
Robert Burgholzer
>===== Original Message From PostGIS Users Discussion
<postgis-users at postgis.refractions.net> =====
>Just a couple questions.when I run the command "createlang plpgsql
>[DBNAME]" - I'm guessing that means the build that I got already
>includes this language?
>Next, when I run "psql -d independencia -f postgis.sql", I get the
>following notices:
>NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit index
>'spatial_ref_sys_pkey' for table 'spatial_ref_sys'
>NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit index 'gc_pk'
>for table 'geometry_columns'
>NOTICE:  ProcedureCreate: type box3d is not yet defined
>NOTICE:  ProcedureCreate: type spheroid is not yet defined
>NOTICE:  ProcedureCreate: type wkb is not yet defined
>NOTICE:  ProcedureCreate: type chip is not yet defined
>NOTICE:  ProcedureCreate: type geometry is not yet defined
>NOTICE:  COMMIT: no transaction in progress
>Is this an issue I should be concerned about?
>Kind regards,
>Mike
