[postgis-users] Running createlang and postgis.sql
Paul Ramsey pramsey at refractions.net
Tue Jun 3 09:47:22 PDT 2003
At a minimum we appear to have an extraneous 'commit' (or a missing
'begin') in the sql file which needs to be paired up. The other warnings
are normal and can be ignored -- when postgresql creates new types there
is a brief period of chicken-and-egg, when types have been created and
their constructurs have not, which raises a warning.
P.
Robert W. Burgholzer wrote:
> Mike,
> I just had the same question today, thanks for posting it. It seems that all
> is right with the data import and I have successfully added data, and
> retrieved it via avpgcon. So, I would say, no, you needn't be concerned,
> however, I am not the expert, thus all I say is speculation.
> Perhaps this is a newer, more extensive error condition being reported by
> postgresql, are you running postgresql 7.3.3?? (I am)
> Robert Burgholzer
>>===== Original Message From PostGIS Users Discussion
> <postgis-users at postgis.refractions.net> =====
>>Just a couple questions.when I run the command "createlang plpgsql
>>[DBNAME]" - I'm guessing that means the build that I got already
>>includes this language?
>>Next, when I run "psql -d independencia -f postgis.sql", I get the
>>following notices:
>>NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit index
>>'spatial_ref_sys_pkey' for table 'spatial_ref_sys'
>>NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit index 'gc_pk'
>>for table 'geometry_columns'
>>NOTICE:  ProcedureCreate: type box3d is not yet defined
>>NOTICE:  ProcedureCreate: type spheroid is not yet defined
>>NOTICE:  ProcedureCreate: type wkb is not yet defined
>>NOTICE:  ProcedureCreate: type chip is not yet defined
>>NOTICE:  ProcedureCreate: type geometry is not yet defined
>>NOTICE:  COMMIT: no transaction in progress
>>Is this an issue I should be concerned about?
>>Kind regards,
>>Mike
> postgis-users mailing list
