[postgis-users] Segmentation fault error caused by shp2pgsql
Steffen Macke sdteffen at web.de
Fri Nov 28 11:43:27 PST 2003
Hi Carlos,
> ]$ shp2pgsql brazil.shp brazil test > loadbrazil.sql
> Segmentation fault
Which PostGIS version and operating system are you using?
How big is your shapefile?
Can you track down the segmentation fault to a single record?
Is there anything special about this record? (NULL values, etc.)
Did you test the shapefile with other software? How was it created?
Could you provide the problematic shapfile for download somewhere?
Steffen
