[postgis-users] Distance function - error if outside the boundary
Tom Melhuish tmelhuish at webinsightsinc.com
Tue Aug 3 10:51:45 PDT 2004
I'm executing the following Postgis SQL command and if I select the
spatial object within the distance the command works, but I get the
following error message in the Postgresql log:
            ERROR:  cursor "mycursor" does not exist
When I select the spatial object out side the command fails and I get
the following in the Postgresql log file.
ERROR:  syntax error at or near ")" at character 144
LOG:  could not send data to client: Connection reset by peer
LOG:  could not send data to client: Broken pipe
LOG:  unexpected EOF on client connection
The Apache log gives me:
      Premature end of script headers:
The problem I'm having is that I can't trap the error using an "eval"
statement in perl. The $stmt->execute()is where I'm having problems. The
command seams to execute OK but when I try to  test for $@ or  print out
$@ or try a ($stmt->fetchrow_array() I get a "Premature end of script
headers:" error and the program dies with no opportunity to trap the
error.
Can anyone help in showing me a way to trap this error or what I may be
doing wrong? It appears that "mycusror" is declared in the select
statement but maybe lost in the execution part.
If  I copy either SQLcommand  and execute it in psql it runs fine. With
no error messages in the postgresql log file.
Below is the code snippet
$SQLcommand=qq(SELECT layer, ncpin, mapsheet, ownername, addr1, addr2,
addr3, city, state, zip, book, page, value, acreage, pflag, revalue,
market  FROM  jccondo WHERE the_geom &&
GeometryFromText('BOX3D(2103178.38307993 558215.2516,2173267.36692007
611928.4437)',1) AND Distance(GeometryFromText('POINT(2170383.04659743
579103.715194444)',1),the_geom) < 1401.77967680279);
eval {
my $stmt = $dbh->prepare($SQLcommand) ||  &AppletMsg("The table name
doesn't exist or one of the attribute names are not valid...
$GisDataSrc","error");
if ($@) {
&AppletMsg("The table name doesn't exist or one of the attribute names
are not valid... $@","error <mailto:$@%22,%22error> ");
eval {
$stmt->execute() or  &AppletMsg("Can't execute select items on
$GisDataSrc - $DBI::errstr ","error");
if ($@) {
&AppletMsg("Can't execute select items... $@","error
$colctr=1;
while (@tname = ($stmt->fetchrow_array())) {
      foreach $value (@tname) {
            if  ($colctr == $NumAttrItems+1 ){
                  $ItemNum++;
                  $colctr=1;
            $QueryResultsmatrix[$ItemNum]->[$colctr]=$value
$colctr++;
$stmt->finish();
I'm running the following versions:
    Postgis 0.8.1
    Postgresql 7.4.1
    DBI    1.40
    Redhat 9.0
Please let me know if I need to provide any other information to help
debug the program.
Thanks in advance for your help.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040803/36f271d7/attachment.html>
