[postgis-users] Distance function - problem when no data found
Tom Melhuish tmelhuish at webinsightsinc.com
Thu Aug 5 12:08:29 PDT 2004
I haven't received any feedback on my previous notes regarding this
problem, so I updated my system to the latest version levels and still
get the same error messages:
Postgis 0.8.2,   Postgresql 7.4.3,    DBI    1.43, DBD_pg 1.32, RH 9.0
I'm executing the following Postgis SQL command and if I select the
spatial object within the distance the command works, but I get the
following error message in the Postgresql log:
            ERROR:  cursor "mycursor" does not exist
When I select the spatial object out side and no data is found the
command fails and I get the following in the Postgresql log file.
ERROR:  syntax error at or near ")" at character 144
LOG:  could not send data to client: Connection reset by peer
LOG:  could not send data to client: Broken pipe
LOG:  unexpected EOF on client connection
The Apache log gives me:
      Premature end of script headers:
If  I copy either SQLcommand  and execute it in psql it runs fine. With
no error messages in the postgresql log file.   I also have this same
command in PostGis 0.7.4 and postgresql 7.3.2 and it works fine.
Please let me know if I need to provide any other information to help
debug the program.
This is a very common PostGis command and was curious if anybody else is
getting an empty array back if no items are found within the circular
boundary with no errors in the logfile?
Below is the code snippet
$SQLcommand=qq(SELECT layer, ncpin, mapsheet, ownername, addr1, addr2,
addr3, city, state, zip, book, page, value, acreage, pflag, revalue,
market  FROM  jccondo WHERE the_geom &&
GeometryFromText('BOX3D(2103178.38307993 558215.2516,2173267.36692007
611928.4437)',1) AND Distance(GeometryFromText('POINT(2170383.04659743
579103.715194444)',1),the_geom) < 1401.77967680279);
eval {
my $stmt = $dbh->prepare($SQLcommand) ||  &AppletMsg("The table name
doesn't exist or one of the attribute names are not valid...
$GisDataSrc","error");
if ($@) {
&AppletMsg("The table name doesn't exist or one of the attribute names
are not valid... $@","error <mailto:$@%22,%22error> ");
eval {
$stmt->execute() or  &AppletMsg("Can't execute select items on
$GisDataSrc - $DBI::errstr ","error");
if ($@) {
&AppletMsg("Can't execute select items... $@","error
$colctr=1;
while (@tname = ($stmt->fetchrow_array())) {
      foreach $value (@tname) {
            if  ($colctr == $NumAttrItems+1 ){
                  $ItemNum++;
                  $colctr=1;
            $QueryResultsmatrix[$ItemNum]->[$colctr]=$value
$colctr++;
$stmt->finish();
Thanks in advance for your help.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040805/ba962eac/attachment.html>
