[postgis-users] Re: bug in bbox containment operators
David Blasby dblasby at refractions.net
Fri Feb 6 10:40:44 PST 2004
Greg Janée wrote:
> David Blasby wrote:
>> So, A @ B implies B ~ A, which is what you're seeing.
> Sorry I wasn't clear on what the problem is.  The bug I'm reporting is
> that Postgres is returning items that are not contained within the query
> region.  Look closely at the coordinates in my original email.
Hum -- there was an old bug which I thought we had fixed.
select
geometry_contain(
'POLYGON((-120 30,-119 30,-119 31,-120 31,-120  30))'::geometry,
'POLYGON((-180 -56,-180 85,180 85,180 -56,-180  -56))'::geometry
select
'POLYGON((-120 30,-119 30,-119 31,-120 31,-120  30))'::geometry     ~
These should both give false.
select
geometry_contained(
select
'POLYGON((-120 30,-119 30,-119 31,-120 31,-120  30))'::geometry     @
These should both give true.
If this all works, then try removing the index ("DROP INDEX <index
name>") from your table and running your query again.
If this gives the correct answer, then its a problem with the RTree
implementation.  Try this fix:
Modify postgis_gist_72.c, line about 204 that is currently:
     case RTContainsStrategyNumber:
       retval = DatumGetBool( DirectFunctionCall2( box_contain,
PointerGetDatum(key), PointerGetDatum(query) ) );
change the "box_contain" to "box_contained", recompile, install, create
an index on your table, vacuum analyse and re-try your query.
Does that fix it?
dave
