[postgis-users] Re: bug in bbox containment operators
Greg Janée gjanee at alexandria.ucsb.edu
Mon Feb 9 15:42:16 PST 2004
David Blasby wrote:
>If this all works, then try removing the index ("DROP INDEX <index name>")
>from your table and running your query again.
>If this gives the correct answer, then its a problem with the RTree
>implementation.
The above all worked as you suggested.  The original problematic query
works fine when the index is removed.
>Try this fix:
>Modify postgis_gist_72.c, line about 204 that is currently:
>     case RTContainsStrategyNumber:
>       retval = DatumGetBool( DirectFunctionCall2( box_contain,
> PointerGetDatum(key), PointerGetDatum(query) ) );
>change the "box_contain" to "box_contained", recompile, install, create an
>index on your table, vacuum analyse and re-try your query.
>Does that fix it?
Nope.  Tried the above, but we still see the same bad behavior.  8-(
-Greg
