[postgis-users] check constraint for geometry column
strk strk at keybit.net
Fri Jun 4 06:45:21 PDT 2004
On Fri, Jun 04, 2004 at 09:39:39AM -0400, Robert W. Burgholzer wrote:
> List members,
> I am using postgis 0.8.0, so if this is resolved in tthe latest version,
> please forgive my ignorance.  I am exploring a transform on geom columns,
> and find, as have some others, that it is a torturous process to reassign
> your geometry column SRID, i.e., it can only be done by dropping and
> re-adding the table.
Not true.
You can drop the constraint, re-assign the SRID
and then add the constraint again (or leave it out if you prefer).
--strk;
> I guess I would inquire as to the use of this constraint, is it truly
> necessary? Is it part of an openGIS specification, or just something used
> in the Postgis system as a check and balance? Does anyone have any feelings
> about whether or not a simple "Warning" rather than a constraint would be
> enough?
> I realize of course, that I should just get off my rump and import my
> tables with the proper SRID identified at the time of import, but just
> thought I would inquire, I have a lot of data that would have to be
> re-imported now that I am dealing with projections.
> Thanks for your thoughts,
> r.b.
> Robert Burgholzer
> Environmental Engineer
> MapTech Inc.
> http://www.maptech-inc.com/
> postgis-users mailing list
