[postgis-users] DropGeometryColumn
strk strk at keybit.net
Thu Mar 18 10:05:59 PST 2004
On Thu, Mar 18, 2004 at 06:42:20PM +0100, Jan Hartmann wrote:
> I don't know if I diagnosed this problem correctly, but I regularly
> stumble over the following situation:
> I create a spatial table, and delete it after some time. When I create a
> new spatial table under the same name, I get an error message about
> "duplicate geometry column names". It seems that before deleting a
> spatial table, you *have* to drop manually the geometry column of that
> table with DropGeometryColumn(). I don't know how to remove this column
> after deleting the table, so this leaves me with a database where I
> cannot create tables that have been deleted the wrong way.
> Am I right that this is how it works? If so, could it be remedied, e.g.
> by some sort of trigger on dropping a spatial table?
I think it could be done applying a trigger from
AddGeometryColumn(). Unfortunately the trigger(s) will
have to be hooked on system tables, which postgresql guys
does not like. You can nonetheless try that out and let
us know.
--strk;
