[postgis-users] Re: Help: Performance of spatial query
Jeremy Palmer jpalmer at paradise.net.nz
Wed Mar 24 02:32:45 PST 2004
Hi sorry about my late reply I have been on holiday. I tried using the your
suggested method with the expand function to create a bounding box instead
of using the buffer function
i.e
SELECT  NOD1.id as nod_id1,
        NOD2.id as nod_id2,
        distance_spheroid(NOD1.shape, NOD2.shape,
'SPHEROID["GRS_1980",6378137,298.257222101]')
FROM    node NOD1,
        node NOD2
WHERE   expand(NOD1.shape, 0.000002) && NOD2.shape
AND     distance(NOD1.shape, NOD2.shape) <= 0.000002
AND     NOD1.id < NOD2.id;
However about 3mins into the query it seems that the database crashes and
the client return this
message: " server closed the connection unexpectedly
	This probably means the server terminated abnormally
	before or while processing the request."
I have checked the shape geometries to see if they are valid plus I have
re-created the spatial index but I still get the same error message. Is
there something wrong with my query?
I don't have a great knowledge of how the postgresql backend server works,
is it possible to see debug information as to why the crash occurred?
My postgres version is 7.41 and
Postgis version is CVS from 26/02/2004
Thanks again
Jeremy Palmer
Quoting Paul Ramsey <pramsey at refractions.net>
>Check out the expand function, for a handy shortcut for creating a
>"slightly larger" bbox to use for this problem.
>Chris is right, the slowness is caused by using an expensive function
> (buffer) in the midst of a high volume query.
>On Monday, March 15, 2004, at 09:59 AM, chodgson at refractions.net wrote:
>> I expect that using the geos function to buffer your point is slowing
>> things
>> down because it has to convert into a geos object and back toa postgis
>> object.
>> It would probably be better to just use the distance function, and
>> then in
>> order to index it, build a bounding box which is effectively your
>> buffered
>> point by using the minx() and miny() functions and string
>> concatenation ie.
>> build the wkt of a box object by concatenating some strings with the
>> minx() and
>> miny() function. Your where clause should look something like:
>> WHERE NOD2.shape && (concatenated string using minx/y( NOD1.shape) )
>> AND distance( NOD1.shape, NOD2.shape ) <= 0.2
>> I don't know the exact syntax for the string stuff otherwise I'd give
>> it to
>> you...
>> HTH.
>> Chris
>> Quoting Jeremy Palmer <jpalmer at paradise.net.nz>:
>>> Hi,
>>> I have been trying to complete a query that tries to locate duplicate
>>> points
>>> i.e. points that have been accidentally created twice or more  These
>>> points
>>> may not exactly be in the same geometric position. My basic
>>> methodology is
>>> to complete a 0.2m proximity check for each geometry point in the
>>> database.
>>> The datum of the geometries is in NZGD2000 (basically the same
>>> parameters as
>>> WGS84).
>>> To do this I was using the buffer function with the overlaps operator
>>> to
>>> find points within 0.000002 of a degree (~ 0.2m) of each other. I was
>>> also
>>> trying to stop the point reporting on itself by checking that NOD1.id
>>> NOD2.id. However as explain query shows below my method produces a
>>> Cartesian
>>> product between the 2 aliases of the node table.
>>> Can anyone help me with constructing a more efficient query? I have
>>> provided
>>> the query explain and table details if that helps.
>>>        NOD2.id as nod_id2,
>>>        NOD1.shape as shape1,
>>>        NOD2.shape as shape2
>>> FROM node NOD1,
>>>           node NOD2
>>> WHERE NOD2.shape && buffer(NOD1.shape, 0.000002)
>>> Explain Query was
>>>   Nested Loop  (cost=590312.88..5062636139085.67 rows=3509048593179
>>> width=288)
>>>    Join Filter: (("inner".shape && buffer("outer".shape, 2e-06::double
>>> precision)) AND ("outer".id < "inner".id))
>>>    ->  Seq Scan on crs_node nod1  (cost=0.00..379897.88 rows=10260188
>>> width=144)
>>>    ->  Materialize  (cost=590312.88..903329.76 rows=10260188
>>> width=144)
>>>          ->  Seq Scan on crs_node nod2  (cost=0.00..379897.88
>>> rows=10260188
>>> width=144)
>>> Table "public. node"
>>>      Column      |         Type         | Modifiers
>>>  id              | integer              | not null
>>>  cos_id_official | integer              | not null
>>>  type            | character varying(4) | not null
>>>  status          | character varying(4) | not null
>>>  order_group_off | integer              | not null
>>>  sit_id          | integer              |
>>>  alt_id          | integer              |
>>>  wrk_id_created  | integer              |
>>>  se_row_id       | integer              |
>>>  audit_id        | integer              | not null
>>>  shape           | geometry             |
>>> Indexes:
>>>     "pkey_node" primary key, btree (id)
>>>     "nod_aud_id" unique, btree (audit_id)
>>>     "fk_nod_alt" btree (alt_id)
>>>     "fk_nod_cos" btree (cos_id_official)
>>>     "fk_nod_sit" btree (sit_id)
>>>     "fk_nod_wrk" btree (wrk_id_created)
>>>     "nod_shape_index" gist (shape)
>>> Check constraints:
>>>     "$1" CHECK (srid(shape) = 104108)
>>>     "$2" CHECK (geometrytype(shape) = 'POINT'::text OR shape IS NULL)
>>> Thank you very much
>>> Jeremy Palmer
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
 >     Paul Ramsey
 >     Refractions Research
 >     Email: pramsey at refractions.net
 >     Phone: (250) 885-0632
End of postgis-users Digest, Vol 17, Issue 24
