[postgis-users] ERROR: relation "Linienzug" does not exit
Randy.Goss at kimley-horn.com Randy.Goss at kimley-horn.com
Wed Mar 24 05:00:49 PST 2004
If you did create the table as 'Linienzug' then you will need to quote the table when you reference it.
For instance:    insert into "Linienzug" (oid.....
Verify the actual name of the table in your schema.  Postgres will force names to lower case unless you quote them.
-----Original Message-----
From: Stefan Donath [mailto:DonathStefan at gmx.de]
Sent: Wednesday, March 24, 2004 5:24 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] ERROR: relation "Linienzug" does not exit
I'm using PostGIS 0.8.1. I created a table 'Linienzug' with the colums oid
(oid), Name (varchar(25)) and Geom (public.geometry).
I tried to insert data using the following command:
INSERT INTO Linienzug (oid,Name,Geom) VALUES
(1,'Linie_1',geometryfromtext('LINESTRING(5589287.1 4570062.5,5589288.0 4570069.0,5589260.0 4570050.9)'));
but received the error message: ERROR: relation "Linienzug" does not exit.
Owner of Linienzug is postgres and i'm connected to PostGIS as postgres,
What's wrong? Can anybody help??
Thanx, Stefan.
+++ NEU bei GMX und erstmalig in Deutschland: TÜV-geprüfter Virenschutz +++
100% Virenerkennung nach Wildlist. Infos: http://www.gmx.net/virenschutz
postgis-users mailing list
