[postgis-users] Help with spatial query (bug??)
strk at refractions.net strk at refractions.net
Wed Apr 6 03:54:14 PDT 2005
Brent, can you post a simplified test of your problem so we can
check on newer geos/postgis versions ?
2 geometries and 2 queries against them should be enough AFAIKT.
--strk;
On Tue, Apr 05, 2005 at 10:38:55PM -0700, Brent Wood wrote:
> --- Carl Anderson <carl.anderson at vadose.org> wrote:
> Thanks Carl.
> Apologies for the length of this post, but I can't see why what I think is
> effectively the same query returns two different results.
> My problem turned out to be that a linestring with 2 points does not intersect
> with (or relate to) the polygon containing it if the startpoint = endpoint. So
> some 10000 records with 0 length lines disappeared from the join.
> I'm not sure if this constitutes a bug or not (I'm using v0.8 & can't change
> that easily)
> All the linestrings in this data subset have 2 points.
> Each of the two points is the same, so the lines are zero length.
> Each cell is a lat/long square, so the bounding box is the actual polygon.
> (In the main dataset, where non-zero length lines are present, the queries
> appear to work correctly for non-zero length linestrings)
> Query one:
> psql $DB -c "select t.event_key,
>                     c.cell_id,
>                     x(startpoint(t.the_geom)),
>                     y(startpoint(t.the_geom)),
>                     c.the_geom
>              from chat_cells3 c,
>                   test_junk t
>              where c.the_geom && t.the_geom;"
> The output shows lines on the boundary of cells, with all the cells being
> identified which touch or contain the line (point). A line(point) on the vertex
> of four neighbouring cells gets 4 records returned.
>  event_key | cell_id |     x     |    y     |
>      the_geom
>   13683355 |    3553 |     175.5 |    -44.2 | SRID=4326;POLYGON((175.45
> -44.25,175.45 -44.2,175.5 -44.2,175.5 -44.25,175.45 -44.25))
>   13683355 |    3554 |     175.5 |    -44.2 | SRID=4326;POLYGON((175.45
> -44.2,175.45 -44.15,175.5 -44.15,175.5 -44.2,175.45 -44.2))
>   13683355 |    3625 |     175.5 |    -44.2 | SRID=4326;POLYGON((175.5
> -44.25,175.5 -44.2,175.55 -44.2,175.55 -44.25,175.5 -44.25))
>   13683355 |    3626 |     175.5 |    -44.2 | SRID=4326;POLYGON((175.5
> -44.2,175.5 -44.15,175.55 -44.15,175.55 -44.2,175.5 -44.2))
>   13677419 |    8186 | 178.68333 | -42.9833 | SRID=4326;POLYGON((178.65
> -43,178.65 -42.95,178.7 -42.95,178.7 -43,178.65 -43))
>   12583686 |    2910 | 175.01667 | -43.9833 | SRID=4326;POLYGON((175 -44,175
> -43.95,175.05 -43.95,175.05 -44,175 -44))
>   12578235 |    3198 | 175.23333 |   -43.95 | SRID=4326;POLYGON((175.2
> -44,175.2 -43.95,175.25 -43.95,175.25 -44,175.2 -44))
>   12578235 |    3199 | 175.23333 |   -43.95 | SRID=4326;POLYGON((175.2
> -43.95,175.2 -43.9,175.25 -43.9,175.25 -43.95,175.2 -43.95))
>   12497906 |   12481 |    181.65 |    -44.2 | SRID=4326;POLYGON((181.65
> -44.25,181.65 -44.2,181.7 -44.2,181.7 -44.25,181.65 -44.25))
>   12497906 |   12482 |    181.65 |    -44.2 | SRID=4326;POLYGON((181.65
> -44.2,181.65 -44.15,181.7 -44.15,181.7 -44.2,181.65 -44.2))
>   12497906 |   12409 |    181.65 |    -44.2 | SRID=4326;POLYGON((181.6
> -44.25,181.6 -44.2,181.65 -44.2,181.65 -44.25,181.6 -44.25))
>   12497906 |   12410 |    181.65 |    -44.2 | SRID=4326;POLYGON((181.6
> -44.2,181.6 -44.15,181.65 -44.15,181.65 -44.2,181.6 -44.2))
>   12497919 |    3270 | 175.26667 |   -43.95 | SRID=4326;POLYGON((175.25
> -44,175.25 -43.95,175.3 -43.95,175.3 -44,175.25 -44))
>   12497919 |    3271 | 175.26667 |   -43.95 | SRID=4326;POLYGON((175.25
> -43.95,175.25 -43.9,175.3 -43.9,175.3 -43.95,175.25 -43.95))
>   12497936 |    2841 | 174.98333 | -43.8333 | SRID=4326;POLYGON((174.95
> -43.85,174.95 -43.8,175 -43.8,175 -43.85,174.95 -43.85))
>   12497956 |    4856 | 176.38333 | -43.8666 | SRID=4326;POLYGON((176.35
> -43.9,176.35 -43.85,176.4 -43.85,176.4 -43.9,176.35 -43.9))
> (16 rows)
> the second query uses not disjoint, which with this data, I understand should
> give the same result. In fact only 2 records are returned. Same if I use
> intersects, relate, add in an "or touches" etc.
> psql $DB -c "select event_key,
>                     c.cell_id,
>                     c.the_geom
>              from chat_cells3 c,
>                   test_junk t
>                and not disjoint(t.the_geom, c.the_geom);"
> the_geom
>   13683355 |    3626 |  175.5 | -44.2 | SRID=4326;POLYGON((175.5 -44.2,175.5
>   12497906 |   12482 | 181.65 | -44.2 | SRID=4326;POLYGON((181.65 -44.2,181.65
> (2 rows)
> I can't see why I get two different results???
> I guess the simple fix is to move the (or add a new) endpoint some tiny
> distance from the startpoint to create a line of non-zero length.
> Is there a (relatively) simple way to do this in PostGIS v0.8?
> Thanks again,
>   Brent Wood
> > Brent Wood wrote:
> > >I'm trying to make sense of the various spatial operators. I need to join a
> > >table of cells to a table of lines, to create a table where there is a
> > record
> > >for each case where a line passes entirely or partially through a cell.
> > >Looking at the OGC specs was a bit of help, but can anyone explain the
> > >difference between the intersects, overlaps & crosses functions:
> > >ie:
> > >select
> > >where
> > >  lines.geom && cell.geom and
> > ><one of>
> > >  intersects(lines.geom, cell.geom)
> > >  overlaps(lines.geom, cell.geom)
> > >  crosses(lines.geom, cells.geom)
> > >I figure I should be using crosses for this query, but don't undertand the
> > >distinction between these.
> > L -   references the Line geometry
> > A -  references the cell, Polygon (area) geometry
> > intersects (L,A)  -  line and polygon (cell) touch or overlay in any way
> > overlaps (L,A) - is not defined for a line vs polygon  test
> > crosses (L,A) - line is part in and part out of the polygon, but not
> > wholly inside
> > within (L,A) - the line is wholly inside the polygon
> > contains (A,L) - the line is wholly inside the polygon
> > you may want
> >     intersects (lines.geom, cells.geom)
> > or if you want to ignore the touches only relationship
> >    ( crosses (lines.geom, cells.geom) or within(lines.geom, cells.geom) )
> > or
> >    ( intersects (lines.geom, cells.geom) and not touches(lines.geom,
> > cells.geom) )
> > C.
> > >Thanks,
> > >  Brent Wood
> > >_______________________________________________
> > >postgis-users mailing list
> > >postgis-users at postgis.refractions.net
> > >http://postgis.refractions.net/mailman/listinfo/postgis-users
