[postgis-users] avpgcon - workaround/fix
Armin Burger armin.burger at gmx.net
Fri Dec 2 11:42:55 PST 2005
Robert
in the last time I had again some looks on avpgcon. I already modified
some parts to work with newer versions of PostGIS. I still have to
remove a bug when accessing Postgres on other ports than 5432 and modify
the identify function. If you're interested I can send you a copy when
it'll be mainly done.
Armin
Robert Burgholzer wrote:
> This from the “WayBack Machine”:
> Don’t know if anyone is still using avpgcon.avx, but I still use ArcView
> 3.3 a bit, and so use avpgcon. This fix relates to that.
> When loading a shape from postgis an error is thrown when avpgcon tests
> to see if the shape is within the current extent, i.e.:
> SELECT gid, shapename, the_geom
> FROM pg_table
> WHERE
> the_geom && GeometryFromText('BOX3D(-356801.233852
> 3928796.210200,649032.548074 4927586.338191)'::box3d,-1)
> Seems that the newer version of geometryFromText don’t like the Box3d,
> however, if you simply change the “GeometryFromText” to “Transform”, as
> in :
> FROM pg_table
> WHERE
> the_geom && transform('BOX3D(-356801.233852 3928796.210200,649032.548074
> Everything appears to be hunky-dory.
> Robert W. Burgholzer
> Nonpoint Source Data Analyst
> University of Maryland, College Park
> Chesapeake Bay Program Office
> 410 Severn Avenue, Suite 305B
> Annapolis, MD, 21403
> Phone: (410) 267-5779
> rburghol at chesapeakebay.net <mailto:rburghol at chesapeakebay.net>
> http://www.chesapeakebay.net/
> postgis-users mailing list
