[postgis-users] Initial SRS and geometry columms table creation
Ivan Kautter ivankautter at hotmail.com
Tue Dec 13 20:16:50 PST 2005
Listserv subscribers,
I am just starting out with PostgreSQL and PostGIS.  It appears that it is
necessary to create the SRS and geometry_columns tables before importing
ESRI shapefile data.  Is this correct?  One thing that seems odd though is
that in order to create the geometry_columns table one would have to know
what tables are going to be produced by importing GIS data into the database
and the resulting name of the geometry_column.
I am also wondering if it is necessary to create a spatial table first for
each shapefile that one is adding to the database or if one may merely use
the loader to create the feature table then modify it by adding a geometry
column to it.
Lastly, I have a spatial reference system that is not defined in EPSG.  It
is a system for the entire state of California in NAD83 defined thusly:
  # California ALBERS projection information
  PROJECTION
    "proj=aea"
    "y_0=-4000000.0"
    "lon_0=-120.0"
    "lat_0=0.0"
    "lat_1=34.0"
    "lat_2=40.5"
    "units=m"
    "ellps=GRS80"
    "datum=NAD83"
How should I go about specifying the SRID, AUTH_NAME, AUTH_SRID for this
custom SRS?  Is there a standard domain for these fields that people utilize
in PostGIS or are the values in these fields largely arbitrary?
Thanks for your time and attention.  All assistance greatly appreciated.
Ivan Kautter
