[postgis-users] 1.0.0 RC1 Ready For Download
strk at refractions.net strk at refractions.net
Mon Jan 17 03:36:23 PST 2005
On Mon, Jan 17, 2005 at 12:24:18PM +0100, Bernhard Herzog wrote:
> Paul Ramsey <pramsey at refractions.net> writes:
> > The 1.0.0 release candidate #1 is now packaged and ready for download.
> > http://postgis.refractions.net/postgis-1.0.0-rc1.tar.gz
> I tested this a little with Thuban, by running Thuban's test-suite with
> this postgis version and PostgreSQL 7.4.6.  The one real problem I ran
> into was that AddGeometryColumn does not quote the column name properly
> when deriving names of contraints from it.  The attached patch fixes
> that.
Thank you, applied.
> Another, minor thing I ran into was that the postgis initialization
> SQL-script has been renamed to lwpostgis.sql.  Once I had extended the
> test suite to look for that file too and fixed the above quoting bug,
> all Thuban tests ran successfully.
>    Bernhard
Good new!
--strk;
> Intevation GmbH                                 http://intevation.de/
> Skencil                                           http://skencil.org/
> Thuban                                  http://thuban.intevation.org/
Content-Description: Quote column name properly in AddGeometryColumn
> postgis-users mailing list
For standing up against patentability of software,
  Thank You, Poland!
Read the intervention:    http://kwiki.ffii.org/ConsPolon041221En
Send your thanks:         thankyoupoland.info
Read/do more:		  http://www.noepatents.org/
