[postgis-users] Crash when creating index on ( int, geom )
strk at refractions.net strk at refractions.net
Sun Jan 30 11:54:55 PST 2005
On Sun, Jan 30, 2005 at 01:13:14PM -0500, Robin Chauhan wrote:
> I eventually discovered that I was meant to attach gdb to the
> particular postgres instance, not the postmaster.  However I'm not
> sure the bt output is very useful.  Would I need to rebuild postgres
> with debug enabled to get anything more meaningful?
Yes!
--strk;
> (gdb) attach 30603
> Attaching to Pid 30603
> 0x2ac26b22 in ?? ()
> (gdb)
> (gdb) cont
> Continuing.
> Program received signal SIGSEGV, Segmentation fault.
> 0x8082f0f in ?? ()
> (gdb) bt
> #0  0x8082f0f in ?? ()
> #1  0x815fe3f in ?? ()
> #2  0x2ae553af in ?? ()
> #3  0x81604b5 in ?? ()
> #4  0x8071b7c in ?? ()
> #5  0x807112f in ?? ()
> #6  0x806e574 in ?? ()
> #7  0x806e4c6 in ?? ()
> #8  0x806e3d6 in ?? ()
> #9  0x8160d7c in ?? ()
> #10 0x807b4d1 in ?? ()
> #11 0x80cfe5d in ?? ()
> #12 0x80cc6fc in ?? ()
> #13 0x80cc2c3 in ?? ()
> #14 0x80cb82d in ?? ()
> #15 0x81175b2 in ?? ()
> #16 0x8115c67 in ?? ()
> #17 0x8116c09 in ?? ()
> #18 0x80ff013 in ?? ()
> #19 0x80fe8b3 in ?? ()
> #20 0x80fdb7d in ?? ()
> #21 0x80fd750 in ?? ()
> #22 0x80dd93e in ?? ()
> #23 0x2ab8c9cb in ?? ()
> (gdb)
> On Sat, 29 Jan 2005 17:07:09 -0500, Robin Chauhan
> <robin.chauhan at gmail.com> wrote:
> > Hello Mark,
> > I'm attempting to generate a backtrace as you suggested.  I was able
> > to attach gdb to the postmaster process, but I dont know how to make
> > gdb break when the failure occurs -- I dont know where I would set a
> > breakpoint or watchpoint to be able to catch this event.  When I Can
> > you give me a hint or pointer?  I think no core file is being
> > generated from the crash, because the postmaster and psql processes
> > both continue to run.
> > Should I be debugging the psql process and not the postmaster process?
> > I tried causing this crashing both while attached to psql and
> > postmaster but again I dont know how to cause gdb to stop at a useful
> > place to see the backtrace of the crash, and not just of the normal
> > running of postmaster.   This is noob territory for me, so please
> > excuse the ignorant questions.
> > Many thanks,
> > -Robin
> > On Fri, 21 Jan 2005 17:35:16 -0000, Mark Cave-Ayland
> > <m.cave-ayland at webbased.co.uk> wrote:
> > > Hi Robin,
> > > If you're ok working with source code then I would also compile and use the
> > > latest 7.3 release which is currently 7.3.8 with --enable-debug. Create a
> > > fresh database cluster with initdb, load your data, and try again. If it
> > > still fails then it's fairly certain to be a bug, perhaps something subtle
> > > in the PostGIS indexing code or with btree_gist. The backtrace should give
> > > us more information on this.
> > > Kind regards,
> > > Mark.
> > > WebBased Ltd
> > > South West Technology Centre
> > > Tamar Science Park
> > > Plymouth
> > > PL6 8BT
> > > T: +44 (0)1752 791021
> > > F: +44 (0)1752 791023
> > > W: http://www.webbased.co.uk
> > > > -----Original Message-----
> > > > From: postgis-users-bounces at postgis.refractions.net
> > > > [mailto:postgis-users-bounces at postgis.refractions.net] On
> > > > Behalf Of Robin Chauhan
> > > > Sent: 21 January 2005 17:23
> > > > To: Mark Cave-Ayland; PostGIS Users Discussion
> > > > Subject: Re: [postgis-users] Crash when creating index on (
> > > > int, geom )
> > > > Mark,
> > > > I tried duplicating the table and got the same reuslt with
> > > > the new table.  Thanks for your instructions on getting a
> > > > backtrace using gdb.
> > > > Before I tried that, I also attempted to install a more
> > > > updated version of btree_gist from here:
> > > > http://www.sai.msu.su/~megera/postgres/gist/btree_gist/btree_g
> > > > ist-7.4.tar.gz
> > > > ...which in the README says it can work on postgres 7.3 and
> > > > up (I have 7.3.2).  Unfortunately I was not able compile it:
> > > > btree_common.c: In function `gbtreekey_in':
> > > > btree_common.c:18: warning: implicit declaration of function `ereport'
> > > > btree_common.c:19: warning: implicit declaration of function `errcode'
> > > > btree_common.c:19: `ERRCODE_FEATURE_NOT_SUPPORTED' undeclared
> > > > (first use in this function)
> > > > btree_common.c:19: (Each undeclared identifier is reported only once
> > > > btree_common.c:19: for each function it appears in.)
> > > > btree_common.c:20: warning: implicit declaration of function `errmsg'
> > > > btree_common.c: In function `gbtreekey_out':
> > > > btree_common.c:29: `ERRCODE_FEATURE_NOT_SUPPORTED' undeclared
> > > > make: *** [btree_common.o] Error 1
> > > > For now I am using the separate indexes as suggested by
> > > > Markus which is working very well, but I will try to track
> > > > this down further.
> > > > -Robin
> postgis-users mailing list
