[postgis-users] Re: Help with finding multi-variate clusters
Paul Ramsey pramsey at refractions.net
Wed Jul 13 07:58:28 PDT 2005
Dylan,
Are you calculating clusters on the fly? Do you need to? How about
having a clusters table, that is hooked to your base data table with
a trigger? That will be just as up-to-date as your base data, and
only have to do the calculations once per data update.
Paul
PS. A distance threshold "cluster" will return lots of unexpected and
unwanted results, which is why more sophisticated tricks have been
developed.
On 13-Jul-05, at 6:57 AM, Eli Dylan Lorimer wrote:
> Hi Stephen,
> Thanks for your reply. I might look into writing that function as
> you suggested, but I feel slightly limited in that I'm making the
> SQL requests in the form of a WFS request to GeoServer which in
> turn is speaking to PostGIS and so I'm not sure if I can add my own
> functions and then have my WFS requests trigger them. I'll have to
> look into this and figure it out.
> I see what you are saying, it being an iterative algorithm and not
> really suited for set operations as such. Hum, I still feel like
> with the spatial operators there must be a way to get what I'm
> looking for, even if I have to make multiple WFS requests or
> something.
> Maybe someone else on this list might know of a way to do this?
> Anyway, cheers.
> ./dylan
> postgis-users mailing list
