[postgis-users] SQL query to identify tables and views with geometry field
Armin Burger armin.burger at gmx.net
Fri Nov 25 12:56:32 PST 2005
Thanks. I think that the query
SELECT c.relname
FROM pg_attribute a, pg_class c, pg_type t
WHERE a.attrelid=c.oid
   AND a.atttypid=t.oid
   AND t.typname='geometry'
   AND (c.relkind = 'r' OR c.relkind = 'v')
should give the correct results.
Armin
jcradock at me3.com wrote:
> Armin,
> Ah.
> Look in pg_catalog. I believe qGIS is querying these tables. Probably
> pg_attribute joined to pg_type joined to pg_table.
> http://www.postgresql.org/docs/8.1/interactive/catalogs.html
> Jim
>>But this query does not find the views based on tables, even if the
>>tables themselves are registered in geometry_columns. Programs like QGIS
>>and uDig seem to be able to find all tables and views with geometry
>>columns, so I guess there seems to be a SQL query based on PG system
>>tables for this.
>>Armin
>>Sean Gillies wrote:
>>>On Nov 25, 2005, at 12:28 PM, Armin Burger wrote:
>>>>Hi everyone,
>>>>is there a way to find all tables and views in a PostGIS-enabled
>>>>database that contain a geometry field, using just a SQL query?
>>>>Armin
>>>If your database is in proper shape
>>>  select f_table_name from geometry_columns;
>>>cheers,
>>>Sean
>>>Sean Gillies
>>>sgillies at frii dot com
>>>http://zcologia.com/news
>>>_______________________________________________
>>>postgis-users mailing list
>>>postgis-users at postgis.refractions.net
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
> James Cradock, jcradock at me3.com
