[postgis-users] Instllation problem on WinXP
Akio Takubo takubo at saruga-tondara.net
Thu Nov 2 10:36:30 PST 2006
On Tue, 31 Oct 2006 11:07:30 +0000
Mark Cave-Ayland <mark.cave-ayland at ilande.co.uk> wrote:
> On Fri, 2006-10-27 at 03:06 +0900, Akio Takubo wrote:
> > Hello all,
> > I have a strange problem with PostGIS installer for Win32.
> > Have anyone experienced these problem?
> > In my case ...
> > I failed install into only WinXP SP2 *Japanese* edition,
> > when I tryed PostGIS installer with some environments.
> > Some user also said that they have same problem with WInXP SP2 (Japanese).
> > This is a list of my test environments and its result. All env are Win32 not Win64.
> > * WinXP Pro SP2 (Japanese) failed
> > * WinXP Pro SP1 (Japanese) success
> > * WinXP Pro SP2 (English) success
> > * Win2003 Server SP1 (Japanese) success
> > I got same above result by all these installers.
> > * pgInstaller(PostgreSQL 8.1.4) + PostGIS installer (1.1.3)
> > * pgInstaller(PostgreSQL 8.1.5) + PostGIS installer (1.1.5)
> > * pgInstaller(PostgreSQL 8.2beta2 with PostGIS 1.1.5)
> > So there is no problem on SP1 or English ver or Win2003server.
> > But at least I can sucess install WinXP SP2 (Japanese) following combination.
> > * pgInstaller(PostgreSQL 8.1.4 + PostGIS 1.0.5 or PostGIS1.0.6)
> > * pgInstaller(PostgreSQL 8.1.4) + PostGIS 1.1.3 (I built with Linux/Mingw32 envrironment)
> > This error occured a runtime of lwpostgis.sql.
> > One example error message is:
> >    psql:../share/contrib/lwpostgis.sql;;35 ERROR:  could not load library
> >    "C:/Program Files/PostgreSQL/8.1/lib/liblwgeom.dll": ( Error message in japanese)
> > It seems that LoadLibrary API fails to load liblwgeom.dll with 998 (ERROR_NOACCESS) error.
> > I thought that there is some compatibility issue (C++ memory managemnet related?)
> > with WinXP SP2 japanese and current PostGIS build envirnment.
> > Can anyone solve this?
> > Best regards,
> >    Akio Takubo @ OSGeo-Japan
> Hi Akio,
> The only reason I can think of as to why liblwgeom.dll would fail to
> load under SP2 is that Windows cannot find a dependent DLL. The setup
> used to build the installer is WinXP SP2 English, and as you correctly
> note, the installer works fine under this setup.
> A useful starting point would be to run the Microsoft Dependency Checker
> (depends.exe) and FileMon (filemon.exe) on your SP1 and SP2 installs to
> determine if there are any dependency differences between the two
> versions of Windows - both of these utilities can be found using Google.
> Posting any differences back to the list should help give a better
> picture as to why PostgreSQL is failing to load the DLL.
> Kind regards,
> Mark.
Sorry for reporting more info too late.
Now I've just finished to test postgis installer with some tools.
I tested with XP SP2(japanese) and XP SP2 (English).
Filemon shows a large diffrence for these two environment.
As postgis installer run lwpostgis.sql, liblwgeom.dll wad read.
In English env, reading libgeos_c-1.dll, libgeos-2.dll and libproj.dll were also
accessed just after liblwgeom.dll. But in Japanese env, only liblwgeom.dll was read,
and other three libraries were not accessed. Both environment seem to have same
directory tree and files. I can't find any diffrence or condition.
At last  I made small program only to load liblwpostgis.dll with "LoadLibrary" function.
It works fine to do "LoadLibrary" for both environment...
Above is all my examing result.
Can I get other useful information from my environment?
Best regards,
