[postgis-users] Re: Further PostGIS / GEOS problems
strk at refractions.net strk at refractions.net
Thu Nov 2 11:42:45 PST 2006
On Thu, Nov 02, 2006 at 05:38:48PM +0000, Mark Cave-Ayland wrote:
> > >  ./configure --prefix=/usr --with-pgsql=/usr/bin/pg_config
> > > --with-geos=/usr/bin/geos-config --with-proj=/usr
> (looks closer)... can you try running configure without the --prefix
> option? I think this is what is causing liblwgeom.so.1.1 to be installed
> in the wrong location,
mmm... --prefix=/usr => lib in /usr/lib is *intended* behaviour
(or about it), this should modify the lwpostgis.sql file
to point to the *full* path to library. If this doesn't work
it's a bug.
