RESOLVED Re : [postgis-users] why a longitude like 180 are not valid in WGS84 in postgis ?
Norbert jsubei at yahoo.fr
Fri Nov 17 02:45:53 PST 2006
;-) I'a really beginner !
yes ok, my problem was the use of conversion fonction GeometryFromText()
We have to explicitly set the srid, even if the postgis/database column is already specified with a specific srid.
example :
GeometryFromText('POINT(long lat)') or  GeometryFromText('POINT(long lat)', -1) will not work
GeometryFromText('POINT(long lat)', 4326) work.
==> GeometryFromText() it's not a contextual function !
(and GeometryFromText('POINT(-54 158)', 4326) work too ! but lot of thanks Guido)
----- Message d'origine ----
De : Guido Lemoine <guido.lemoine at jrc.it>
À : PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Envoyé le : Vendredi, 17 Novembre 2006, 11h26mn 22s
Objet : Re: [postgis-users] why a longitude like 180 are not valid in WGS84 in postgis ?
try POINT (158.93 -54.51)
Notation is in X Y = LON LAT! 158.93 is far beyond the North Pole :-)
GL
Norbert wrote:
>Hi all,
>Can you explain to me why a point like POINT(-54.51 158.93) is not valid in wgs84 / srid 4326 in PostGIS and make a conflict "enforce_srid_coordinates" ?
>What's the error and solution ?
>thanks in advance,
>Norbert
>___________________________________________________________________________
>Découvrez une nouvelle façon d'obtenir des réponses à toutes vos questions !
>Profitez des connaissances, des opinions et des expériences des internautes sur Yahoo! Questions/Réponses
>http://fr.answers.yahoo.com
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Joint Research Centre, European Commission
Institute for the Protection and Security of the Citizen (IPSC)
Unit: Support to External Security
Via E. Fermi, 1 TP 267 Ispra 21020 (VA), Italy
Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
WWW: http://ses.jrc.it
Disclaimer:
Views expressed are those of the individual and do not represent the
views of the European Commission
