[postgis-users] oid indexes issue
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Fri Nov 24 05:56:08 PST 2006
I'm attempting to recast a database instance with some scripts developed
against PostGIS 1.1.1.  Below is a code snippet of the init:
# CREATE TABLE service_endpoints (
 resource_id serial primary key,
 title text,
# SELECT AddGeometryColumn
('service_endpoints','the_geom',4326,'MULTIPOLYGON',2);
# CREATE INDEX service_endpoints_idx ON service_endpoints USING GIST (
the_geom GIST_GEOMETRY_OPS );
# CREATE INDEX service_endpoints_idx_oid ON service_endpoints ( oid );
This works successfully against
- POSTGIS="1.1.1" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.5.0, 22 Oct 2006"
USE_STATS DBPROC="0.3.0" RELPROC="1.1.1" (needs proc upgrade)
(1 row)
- PostgreSQL 8.1.2
- FC4
This does NOT work successfully against:
- POSTGIS="1.1.6" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.5.0, 22 Oct 2006"
USE_STATS
- PostgreSQL 8.1.5
- MS Windows Server 2003
The error message I received when running against the latter environment
is:
"ERROR:  column "oid" does not exist"
Are oid's no longer supported?
Thanks
..Tom
