[postgis-users] intersection/within queries - newbie basicspatial queries
Kevin Neufeld kneufeld at refractions.net
Fri Dec 7 09:16:23 PST 2007
Correct.  This JOIN query is the same thing that I posted yesterday, but
using a WHERE clause instead.
Josh,
A quick note on your comment about gist indexes.  I totally agree with
you that you need the && operator, but now in postgis, most of the st_*
methods are simple wrappers of previous methods and include the && operator.
i.e.
test=# \df+ st_within
                                                            List of
functions
 Schema |   Name    | Result data type | Argument data types |  Owner
| Language |              Source code              | Description
 public | st_within | boolean          | geometry, geometry  | postgres
| sql      | SELECT $1 && $2 AND _ST_Within($1,$2) |
(1 row)
In fact, I've noticed that sometimes adding an extra && operator can
make a query take longer.  Here is an example two tiny tables I have:
test=# explain analyze
select a.* from neighbourhood_poly a, cityarea_poly b
where st_within(a.the_Geom, b.the_Geom);
                                                        QUERY
PLAN
 Nested Loop  (cost=1.03..4.24 rows=19 width=30271) (actual
time=2.391..121.782 rows=15 loops=1)
   Join Filter: ((a.the_geom && b.the_geom) AND _st_within(a.the_geom,
b.the_geom))
   ->  Seq Scan on neighbourhood_poly a  (cost=0.00..1.26 rows=26
width=30271) (actual time=0.049..0.233 rows=26 loops=1)
   ->  Materialize  (cost=1.03..1.06 rows=3 width=15506) (actual
time=0.006..0.192 rows=3 loops=26)
         ->  Seq Scan on cityarea_poly b  (cost=0.00..1.03 rows=3
width=15506) (actual time=0.015..0.028 rows=3 loops=1)
 Total runtime: 122.979 ms
(6 rows)
and b.the_geom && a.the_geom;
                                                        QUERY
PLAN
 Nested Loop  (cost=1.03..4.44 rows=14 width=30271) (actual
time=4.176..190.813 rows=15 loops=1)
b.the_geom) AND (b.the_geom && a.the_geom))
width=30271) (actual time=0.048..0.658 rows=26 loops=1)
time=0.012..0.110 rows=3 loops=26)
width=15506) (actual time=0.125..0.140 rows=3 loops=1)
 Total runtime: 191.687 ms
(6 rows)
This looks like it's due to the fact that the && operator is not truely
symmetric and the query planner does not disregard the extra index lookup.
Cheers,
Kevin
Obe, Regina wrote:
> You are missing an ON. You can fix by moving your where into the ON
> SELECT sec_catch.secondary
> FROM sec_catch INNER JOIN prim_catch ON st_within(sec_catch.the_geom,
> prim_catch.the_geom)
> I tend to spell out the type of JOIN too because I can never remember
> what is the default join behavior in PostgreSQL.
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Craigie Dirk
> Sent: Friday, December 07, 2007 1:42 AM
> To: postgis-users at postgis.refractions.net
> Cc: dylan
> Subject: RE: [postgis-users] intersection/within queries - newbie
> Thanks,
> 1st case worked perfectly - thanks.
> 2nd case (more what I am after) gave a syntax error at or near "where"
> Any ideas on the error ?
> select sec_catch.secondary
> from sec_catch join prim_catch
> where st_within(sec_catch.the_geom, prim_catch.the_geom)
> Regards,
> Dirk Craigie
> From: dylan [mailto:debeaudette at ucdavis.edu]
> Sent: 07 December 2007 08:27 AM
> Cc: Craigie Dirk
> Subject: Re: [postgis-users] intersection/within queries - newbie basic
> spatial queries
> On Thursday 06 December 2007 10:02:57 pm Craigie Dirk wrote:
>> I am a new user and trying to perform some basic spatial queries using
>> within/intersect/union etc.
>> I have 2 x polygon files :
>> Prim_catch (19 x records)
>> Sec_catch (attribute secondary = text field name of catchment)
>> All the polys in sec_catch fall within a single record (polygon) of
>> prim_catch
>> The query I am using (see below) needs some kind of loop or temporary
>> table as it returns a true/false and not a list of the records = true.
>> SELECT secondary FROM sec_catch
>> WHERE WITHIN((select the_geom from sec_catch),(select the_geom from
>> prim_catch))
> Using a join can save typing:
> select st_intersection(a.geom, b.geom) from a join b on
> st_intersects(a.geom,
> b.geom) ;
> if you want the cartesian product (all possible permutations leave off
> the ON
> clause).
> or if you just want matching records:
> select a.id from a join b where st_within(a.geom, b,geom);
> does that help ?
> Dylan
> DISCLAIMER:
> This message and any attachments are confidential and intended solely
> for the addressee. If you have received this message in error, please
> notify the system manager/sender.  Any unauthorized use, alteration or
> dissemination is prohibited.  The Department of Water Affairs and
> Forestry further accepts no liability whatsoever for any loss, whether
> it be direct, indirect or consequential, arising from this e-mail, nor
> for any consequence of its use or storage.
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
