[postgis-users] problem with apostrophe
Andreas Neumann neumann at karto.baug.ethz.ch
Mon Jan 15 14:52:38 PST 2007
Merci beaucoup - ca marche bien ...
Isn't LATIN1 and ISO-8859-1 the same?
Thanks a lot ...
Andreas
TECHER David wrote:
> Andreas Neumann a écrit :
>> [cut]
>> Do you have an idea how I can find out what encoding my shapefile
>> uses? In the Postgis DB I use UTF-8, but my shapefile doesn't seem to
>> use UTF-8. At least it fails if I use UTF-8 as an encoding during
>> conversion process. I have no idea how to find out what encoding the
>> shapefile uses. I used ISO-8859-1 during conversion. It seems to work
>> fine, but it is just a guess encoding that I use now.
>> Thanks,
>> Andreas
> Hi Andreas
> With all french shapefile I'm used to importing in PostGIS, the
> shapefile are in LATIN1 or LATIN9
> Since U are in GNU/Linux U can use iconv or recode
> shp2pgsql -DI [shapefile] [table] | iconv -f LATIN1 -t UTF-8 -c | psql
> [database]
> shp2pgsql -DI [shapefile] [table] | recode l9..u8 | psql [database]
> (with l9 as LATIN9 and u8 as UTF-8)
> Since U understand French have a look on my blog at
> for iconv:
> http://www.davidgis.fr/blog/index.php?2006/11/24/83-importer-un-shapefile-francais-dans-une-base-encodee-en-utf-8
> (for iconv)
> for recode
> http://www.davidgis.fr/blog/index.php?2006/12/09/97-autre-astuce-pour-passer-d-un-shapefile-a-une-base-de-donnees-encode-en-utf-8
> ___________________________________________________________________________
> Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et
> son interface révolutionnaire.
> http://fr.mail.yahoo.com
> postgis-users mailing list
Andreas Neumann
Institute of Cartography
ETH Zurich
Wolfgang-Paulistrasse 15
CH-8093  Zurich, Switzerland
Phone: ++41-44-633 3031, Fax: ++41-44-633 1153
e-mail: neumann at karto.baug.ethz.ch
www: http://www.carto.net/neumann/
SVG.Open: http://www.svgopen.org/
Carto.net: http://www.carto.net/
