[postgis-users] problem with apostrophe
Armin Burger armin.burger at gmx.net
Mon Jan 15 15:13:37 PST 2007
Andreas
as far as I know shapefiles created with ESRI products on Windows use
Win1252 encoding, which is virtually the same as ISO-8859-1 (LATIN1).
Probably LATIN1 is also the default for other shape libraries.
With shp2pgsql you can also use -W "LATIN1" to create the output in UTF.
armin
> Do you have an idea how I can find out what encoding my shapefile uses?
> In the Postgis DB I use UTF-8, but my shapefile doesn't seem to use
> UTF-8. At least it fails if I use UTF-8 as an encoding during conversion
> process. I have no idea how to find out what encoding the shapefile
> uses. I used ISO-8859-1 during conversion. It seems to work fine, but it
> is just a guess encoding that I use now.
> Thanks,
> Andreas
