[postgis-users] Experiment: Glassfish/EJB3 and PostGIS
Gustavo Ces g.ces at pettra.es
Fri May 11 00:02:06 PDT 2007
Hi Bastian,
    in geometry column ( region) you´re trying to insert a null value and
program interprets that as a string one. In that type of columns you only
can insert geometry types. Why it inserts null values as default is not a
postgres sql problem, perhaps a interface one ( i´m not sure). Maybe if geom
coumn is a not null one it doesn´t try to insert a null value, but i don´t
know. But it´s a curious question. How do you insert a null into geometry
type column?
