[postgis-users] Experiment: Glassfish/EJB3 and PostGIS
Bastian Voigt post at bastian-voigt.de
Fri May 11 11:37:48 PDT 2007
Gustavo, Rabbia,
thanks for your replies. As I have now found out, indeed it was a
problem with Toplink Essentials.
Apparently JDBC distinguishes between different types of NULL values.
There is a varchar null value, an integer null value, etc. etc. Toplink
tried to insert a "varchar null" instead of a "geometry null", which
lead to the error message.
I was able to solve this problem now by having toplink use the "NULL
NULL" value, i.e. a null value of type null.
Weird, but it did help ;-)
In case anyone is interested I can post my patch against toplink
essentials 1 Build 14.
Regards
Bastian
Gustavo Ces schrieb:
> Hi Bastian,
>    in geometry column ( region) you´re trying to insert a null value
> and program interprets that as a string one. In that type of columns
> you only can insert geometry types. Why it inserts null values as
> default is not a postgres sql problem, perhaps a interface one ( i´m
> not sure). Maybe if geom coumn is a not null one it doesn´t try to
> insert a null value, but i don´t know. But it´s a curious question.
> How do you insert a null into geometry type column?
> Gus
> postgis-users mailing list
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070511/67400d88/attachment.vcf>
