[postgis-users] Modify encoding of shapefile
Nicolas Ribot nicky666 at gmail.com
Tue May 29 06:29:44 PDT 2007
> I am not sure this is the same problem.
> It looks like your file is in codepage 1252 but your client encoding is set to UNICODE.
> Doesn't "SET client_encoding TO WIN1252;" help in your case ?
Yes, you may be right.
I'm not on windows, though, but on Linux.
The sql script I use worked well on Mac, with the same shapefile.
