[postgis-users] ERROR: Out of memory
Andreas Laggner andreas.laggner at fal.de
Mon Oct 8 01:24:28 PDT 2007
i tried to perform the "union approach" from Kevin
http://postgis.refractions.net/support/wiki/index.php?ExamplesOverlayTables
the first query worked fine:
 CREATE TABLE all_lines AS
   SELECT St_ExteriorRing (the_geom) AS the_geom FROM ffhsinglerep
   UNION ALL
   SELECT St_ExteriorRing (the_geom) AS the_geom FROM spasinglerep;
but in the second one i get an error:
CREATE TABLE noded_lines AS
   SELECT St_Union(the_geom) AS the_geom
   FROM all_lines;
SQL Status:53200
Detail:Failed on request of size 20750552.
If anybody knows what may be behind this error......i have no idea!
Cheers      Andreas
Dipl. Geoökologe Andreas Laggner
Institut für Ländliche Räume (LR)
Bundesforschungsanstalt für Landwirtschaft (FAL)
Institute of Rural Studies
Federal Agricultural Research Centre (FAL)
Bundesallee 50
D-38116 Braunschweig
Tel.: (+49) (0)531 596 5515
Fax: (+49) (0)531 596 5599
E-mail: andreas.laggner at fal.de
Homepage: http://www.lr.fal.de/
