[postgis-users] ERROR: Out of memory
Shane Spencer shane at bogomip.com
Mon Oct 8 09:34:24 PDT 2007
I think you don't have enough memory.  Atleast thats my first assumption :)
What kind of computer system is this running on? What are the hardware
specs? Do you have oodles of swap/paging memory available?  Do you
have enough disk space for Postgresql to create its own temporary
files?
Shane
On 10/8/07, Andreas Laggner <andreas.laggner at fal.de> wrote:
> Hi,
> i tried to perform the "union approach" from Kevin
> http://postgis.refractions.net/support/wiki/index.php?ExamplesOverlayTables
> the first query worked fine:
>  CREATE TABLE all_lines AS
>    SELECT St_ExteriorRing (the_geom) AS the_geom FROM ffhsinglerep
>    UNION ALL
>    SELECT St_ExteriorRing (the_geom) AS the_geom FROM spasinglerep;
> but in the second one i get an error:
> CREATE TABLE noded_lines AS
>    SELECT St_Union(the_geom) AS the_geom
>    FROM all_lines;
> SQL Status:53200
> Detail:Failed on request of size 20750552.
> If anybody knows what may be behind this error......i have no idea!
> Cheers      Andreas
> Dipl. Geoökologe Andreas Laggner
> Institut für Ländliche Räume (LR)
> Bundesforschungsanstalt für Landwirtschaft (FAL)
> Institute of Rural Studies
> Federal Agricultural Research Centre (FAL)
> Bundesallee 50
> D-38116 Braunschweig
> Tel.: (+49) (0)531 596 5515
> Fax: (+49) (0)531 596 5599
> E-mail: andreas.laggner at fal.de
> Homepage: http://www.lr.fal.de/
> postgis-users mailing list
