[postgis-users] ST_MakeBox2D losing precision ?
postgis.domain.thewild at spamgourmet.com postgis.domain.thewild at spamgourmet.com
Fri Oct 12 03:56:14 PDT 2007
Hi list !
First of all, the versions :
PostgreSQL : "PostgreSQL 8.2.0 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC) 3.4.2 (mingw-special)"
PostGIS : "POSTGIS="1.3.1" GEOS="3.0.0rc4-CAPI-1.3.3" PROJ="Rel. 4.5.0, 22 Oct 2006" USE_STATS"
I am trying to modify geometries stored in a table.
They all should be squares with 158.75 meters sides, but some are bigger (vertically). I wrote a query to update them, but I realized that after the update, some geometries where 159 meters high.
Here is the test that shows this behaviour :
	ymax(makebox2d(st_makepoint(xmin(bbox),ymax(bbox)-158.75), st_makepoint(xmax(bbox),ymax(bbox)))) -
	ymin(makebox2d(st_makepoint(xmin(bbox),ymax(bbox)-158.75), st_makepoint(xmax(bbox),ymax(bbox))))
	(st_ymax(bbox)-st_ymin(bbox)) > 158.75;
Results are 158.5 or 159, so it appears that ST_MakeBox2D is losing part of the precision of my points.
I checked the points coordinates returned by ST_MakePoint, and those are OK !
Have I overlooked something ?
I will rewrite this to create a polygon WKT, but I wanted to point this out.
