[postgis-users] ESRI Shapes from database
Brent Wood pcreso at pcreso.com
Fri Oct 19 14:20:50 PDT 2007
--- Lee Keel <lee.keel at uai.com> wrote:
> > Steffen,
> Thanks for the reply, but I am not sure how to call COPY using STDIN.  Do
> you have an example?  I really don't see how to call COPY using STDIN if I
> am using an npgsqlcommand object in .NET.  So I am guessing there is no
> specific permission that I can grant that will allow this?  Bummer.
Hi Lee,
>From the command line, you could use:
cat <file> | psql -d <db> -c "copy <table> from STDIN;"
How this can be invoked in .net I have no idea.... but there si an example :-)
If the user who makes the connection is a postgres superuser, you should be
able to copy to/from files directly.
Another option, are there any .net bindings for GDAL/OGR?
Cheers,
   Brent Wood
