[postgis-users] Upload a shapefile to PostGIS via Web?
Barend Kobben kobben at itc.nl
Thu Aug 14 05:06:44 PDT 2008
Or use the OS gis-viewer QuantumGIS (www.qgis.org) it has a plugin called
SPIT which allows you to load the file in QGIS and then upload to PostGIS...
Barend Köbben
International Institute for Geo-Information
Sciences and Earth Observation (ITC)
PO Box 6
7500AA Enschede, The Netherlands
+31 (0)53 4874253
On 14-08-08 10:51, "Guido Lemoine" <guido.lemoine at jrc.it> wrote:
> Luigi et al,
> If you use a Java environment, you would want to look at Geotools (can
> parse shapefiles to Postgis)
> and a servlet or JSP set-up for multi-part request processing on the
> server. If you are familiar with
> Groovy and Grails, I can recommend that to make the coding a lot easier.
> GL
> Xiaoyu Guan wrote:
>> Hi Luigi:
>> yes, I also see the problem, there are at least two steps, step1: zip
>> all shapefile and upload. step 2: extract zip file, and import to
>> certain database. Maybe there is one way or some people are already
>> working on it. I am think whether possible translate OGR2OGR or
>> Shp2pgsql into python or other languages, which user can runing the
>> conversion part at server side. That s what I am thinking about the
>> solution.
>> Thanks for your reply.
>> All the best
>> Xiaoyu
>> Xiaoyu Guan (Sam)
>> Geo-information Science
>> Wageningen UR
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
International Institute for Geo-Information Science and Earth Observation (ITC)
Chamber of Commerce: 410 27 560
E-mail disclaimer
The information in this e-mail, including any attachments, is intended for the addressee only. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or action in relation to the content of this information is strictly prohibited. If you have received this e-mail by mistake, please delete the message and any attachment and inform the sender by return e-mail. ITC accepts no liability for any error or omission in the message content or for damage of any kind that may arise as a result of e-mail transmission.
