[postgis-users] PostGIS 1.3.3 on Windows XP Unstable
Bresnahan, Mike Mike.Bresnahan at bestbuy.com
Thu Aug 14 16:45:10 PDT 2008
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA256
> FWIW:  The unioning operations currently in PostGIS are very
inefficient.
Do I guess right that PostGIS iterates over each geometry and unions it
with the result of all previous geometries, something like this:
            java.awt.geom.Area area = null;
            for (Geometry geom : geomList) {
                if (area == null) {
                    area = ConvertToArea(geom);
                else {
                    path = area.add(ConvertToArea(geom)); // union
AFAIK, that is what Oracle does and it is quite slow.
> We are working on improving the union operation in PostGIS and
hopefully
> will have at least a first draft to show in the next release.  Most
> notably
> porting the JTS logic for doing Cascaded Unions to PostGIS.
By Cascaded Unions do you mean a routine that works something like this:
            java.awt.geom.Area subArea = null;
            int rowCount = 0;
            while (result.next()) {
                JGeometry geom = JGeometry.load(result.getBytes(1));
                java.awt.Shape shape =
Java2DClipper.geometryToShape(geom);
                if (shape != null) {
                    if (subArea == null) {
                        subArea = new java.awt.geom.Area(shape);
                    else {
                        subArea.add(new java.awt.geom.Area(shape));
                    ++rowCount;
                    if (rowCount % 10 == 0) {
                         if (area == null) {
                            area = subArea;
                        else {
                            area.add(subArea);
                        subArea = null;
                System.out.println(rowCount);
I have found that this is indeed faster that the first approach, but
what I have found that is even faster is to create one large geometry
collection and union it with itself like this:
            java.awt.geom.GeneralPath path = null;
                if (path == null) {
                    path = ConvertToPath(geom);
                else {
                    path = AppendToPath(path, geom);
            java.awt.geom.Area area = new java.awt.geom.Area(path);
            area.add(area); // self-union
I think the gain here is that you only build the temp data structures
for each polygon once. I'm guessing that this is what ArcMap does.
-----BEGIN PGP SIGNATURE-----
Version: PGP Universal 2.8.3
Charset: us-ascii
wsBVAwUBSKTDPR6WPRoYuvd0AQjlRwf/Rci7f0R8jm/deW5Q7kA1tBwXRFSdd3S9
dQwp/Sl/5wTcQc/NbV8kRM5MHeDRPzL2XBUY7zp/ypdLYv5RDi0+niJSmLWiYg5T
vu4ot5Z4de1PjWncSmHNQqqVcNrxy4oxwLtrULgEZ3yMPcW3ffxwHFZzxNBULNCi
VjWISI670HOb/7vmzjgsWrBgPgXl5gMRsDp6eiR+L+SDBBqZJTwHaR6WV86hGsYw
t92QkvKUYNq0DOSmcjnNgIE2xxDuCAABed5ZwLiCF34hP3bN5nnfOs29Fd+yTP/V
pEKxZYrPn/v6RNUNPuw9MhjGEvGA4YkcL6y/Bbf1nnvaK0EseOzwow==
=Y1Pu
-----END PGP SIGNATURE-----
