[postgis-users] Fucntion that find if the x, y, z for any points in the table are the same
eehab hamzeh eehab40 at hotmail.com
Tue Aug 26 06:52:38 PDT 2008
Hello,
I have the following function which check if two (or more) points are one, the function just consider the x,y coordinates. can any body help me to modify it to check z-index also.
Thanks
Ihab
below is the function
-- Function: assign_vertex_id(character varying, double precision, character varying, character varying)
-- DROP FUNCTION assign_vertex_id(character varying, double precision, character varying, character varying);
CREATE OR REPLACE FUNCTION assign_vertex_id(geom_table character varying, tolerance double precision, geo_cname character varying, gid_cname character varying)
RETURNS character varying AS
$BODY$ DECLARE
points record; i record; source_id int; target_id int; pre varchar; post varchar;
BEGIN
BEGIN
DROP TABLE vertices_tmp;
EXCEPTION
WHEN UNDEFINED_TABLE THEN
END;
CREATE TABLE vertices_tmp ( id serial );
EXECUTE $q$ SELECT addGeometryColumn('vertices_tmp', 'the_geom',
(SELECT srid FROM geometry_columns WHERE f_table_name='$q$ quote_ident(geom_table) $q$') , 'POINT', 4) $q$;
CREATE INDEX vertices_tmp_idx ON vertices_tmp USING GIST (the_geom);
pre = ;
post = ;
FOR i in EXECUTE 'SELECT count(*) as t from ' quote_ident(geom_table) ' WHERE NumGeometries??(' quote_ident(geo_cname) ') is not null' loop
IF (i.t > 0) THEN
pre = 'geometryN('; post = ' , 1)';
END IF;
END LOOP;
FOR points IN EXECUTE 'SELECT ' quote_ident(gid_cname) ' AS id,'
' startPoint(' pre quote_ident(geo_cname) post ') AS source,' ' endPoint(' pre quote_ident(geo_cname) post ') as target' ' FROM ' quote_ident(geom_table) loop
source_id := point_to_id(points.source, tolerance); target_id := point_to_id(points.target, tolerance);
EXECUTE 'update ' quote_ident(geom_table)
' SET source_id = ' source_id
', target_id = ' target_id
' WHERE ' quote_ident(gid_cname) ' = ' points.id;
END LOOP;
RETURN 'OK';
END; $BODY$
LANGUAGE 'plpgsql' VOLATILE STRICT COST 100;
ALTER FUNCTION assign_vertex_id(character varying, double precision, character varying, character varying) OWNER TO postgres;
_________________________________________________________________
Discover the new Windows Vista
http://search.msn.com/results.aspx?q=windows+vista&mkt=en-US&form=QBRE
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080826/dc4ddde0/attachment.html>
