[postgis-users] how to identify the_geom that cause:RelateOperation called withLWGEOMCOLLECTION type
Ghislain Geniaux geniaux at avignon.inra.fr
Wed Dec 10 01:06:40 PST 2008
Exact,
  that's the problem :
scot3=# SELECT gid, the_geom
scot3-# FROM bd_dispo_final
scot3-# WHERE isempty(centroid(the_geom));
   gid
        the_geom
  16435 |
0103000020BE6B0000010000000400000081F178483F4F2841D730212506D33C418045F7
1F474F2841D706623902D33C417E45F71F474F2841D806623902D33C4181F178483F4F28
41D730212506D33C41
(1 row)
Here, you will find  the ouput of  pg_dump to study this geometrry.
Thanks again.
-- PostgreSQL database dump
SET client_encoding = 'SQL_ASCII';
SET standard_conforming_strings = off;
SET check_function_bodies = false;
SET client_min_messages = warning;
SET escape_string_warning = off;
SET search_path = public, pg_catalog;
SET default_tablespace = '';
SET default_with_oids = false;
-- Name: bug; Type: TABLE; Schema: public; Owner: postgres; Tablespace:
CREATE TABLE bug (
     gid integer,
     the_geom geometry
ALTER TABLE public.bug OWNER TO postgres;
-- Data for Name: bug; Type: TABLE DATA; Schema: public; Owner: postgres
COPY bug (gid, the_geom) FROM stdin;
16435
41D730212506D33C41
-- PostgreSQL database dump complete
Le 9 déc. 08 à 13:04, Obe, Regina a écrit :
> Ghislain,
> The only time I have seen this kind of behavior is when centroid
> returns an empty geometry collection.  In those cases its because
> the geometry is invalid.
> Although none of your geometries are invalid, it could be a bug in
> either the centroid code or isvalid check that may or may not be
> fixed in 3.0.3+ of GEOS.
> Can you do the following
> FROM ZS2C
> and send us as an attatched file with one of those geometries.  We
> can cross check with GEOS 3.0.3 or 3.1 to see if the issue still
> remains.
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-
> users-bounces at postgis.refractions.net] On Behalf Of Ghislain Geniaux
> Sent: Monday, December 08, 2008 1:29 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] how to identify the_geom that
> On Linux  :
> POSTGIS="1.3.1" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
> 2007" USE_STATS
> (1 row)
> On Macos
>   POSTGIS="1.2.1" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
> 2007" USE_STATS
> (1 row)
> same result with the two platform and postgis version.
> Thanks.
> Le 8 déc. 08 à 17:53, Paragon Corporation a écrit :
>> What does
>> SELECT postgis_full_version();
>> Return
>> Thanks,
>> Regina
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>> Ghislain
>> Geniaux
>> Sent: Monday, December 08, 2008 11:03 AM
>> Subject: Re: [postgis-users] how to identify the_geom that cause
>> I've no collection. It's looks like a bug.
>> Moreover my table is very large wiht more than 500 000 geometry and i
>> found no solution to identy the wrong geom.
>> Here you can see the query, with the same result on different
>> plateform (LINUX DEBIAN, MACOS, with GEOS 3)
>> otm=# select distinct geometrytype(the_geom) from ZS2c;
>>   geometrytype
>>   MULTIPOLYGON
>> (1 row)
>> otm=# select distinct geometrytype(the_geom) from bd_dispo_finalc ;
>>   geometrytype
>>   MULTIPOLYGON
>>   POLYGON
>> (2 rows)
>> otm=# create table info_nonvoue1 as
>> otm-# select b.id_parc, z.niv from bd_dispo_finalc as b, ZS2c as z
>> otm-# where z.niv=1 and intersects(centroid(b.the_geom),z.the_geom)
>> and b.the_geom && z.the_geom and isvalid(b.the_geom) and isvalid
>> (z.the_geom);
>> ERROR:  Relate Operation called with a LWGEOMCOLLECTION type.  This
>> is unsupported
>> otm=#
>> Le 8 déc. 08 à 13:32, Obe, Regina a écrit :
>>> Many of the GEOS relation functions do not work with collections.
>>> You must have a geometry collection in there somewhere or its a bug.
>>> Also which relation function were you trying?
>>> To figure out the type of your geometries, run
>>> SELECT *
>>> FROM sometable
>>> WHERE GeometryType(the_geom) = 'GEOMETRYCOLLECTION'
>>> Nicolas Ribot
>>> Sent: Monday, December 08, 2008 6:22 AM
>>> Subject: Re: [postgis-users] how to identify the_geom that cause :
>>>> I have an error with some geometry that cause : "ERROR Relate
>>> Operation
>>>> called withLWGEOMCOLLECTION type".
>>>> All the geometries seem clean (valid, non empty, closed, only
>>>> POLYGON,
>>>> My question : how to get information of which geometry cause the
>>> problem ?
>>>> Is there a way  to have information about the geometry during
>>>> postgis
>>> is
>>>> working on a  SQL query ?
>>>> Thanks.
>>> Hi Ghislain,
>>> What the query that failed looks like ?
>>> The message is telling that one geometry has an invalid type.
>>> In your query, you could try to ask for ST_GeometryType(geometry)
>>> and
>>> a geometry identifier to see which geometry has the wrong type.
>>> If you perform a spatial operation, it is possible that
>>> geometryCollection is produced.
>>> You could maybe split your query into smaller block to see where
>>> such
>>> collections are generated.
>>> Nicolas
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> The substance of this message, including any attachments, may be
>>> confidential, legally privileged and/or exempt from disclosure
>>> pursuant to Massachusetts law. It is intended
>>> solely for the addressee. If you received this in error, please
>>> contact the sender and delete the material from any computer.
>> Geniaux Ghislain
>> INRA SAD Ecodéveloppement
>> Site Agroparc
>> Domaine St Paul
>> 84914 Avignon Cedex 9
>> Tél : 04 32 72 25 64
>> Fax : 04 32 72 25 62
> Geniaux Ghislain
> Site Agroparc
> Domaine St Paul
Geniaux Ghislain
Site Agroparc
Domaine St Paul
