[postgis-users] how to identify the_geom that cause:RelateOperation called withLWGEOMCOLLECTION type
Fred Lehodey lehodey at gmail.com
Wed Dec 10 02:28:21 PST 2008
just a note:
inserting the same geometry :
INSERT INTO bug (gid, the_geom) VALUES (
1  ,
'0103000020BE6B0000010000000400000081F178483F4F2841D730212506D33C418045F71F474F2841D706623902D33C417E45F71F474F2841D806623902D33C4181F178483F4F2841D730212506D33C41'
and
INSERT INTO bug (gid, the_geom) VALUES (2,st_geomfromtext('POLYGON((
796575.641547725 1889030.1450377,
796579.562433407 1889026.22415202,
796579.562433406 1889026.22415202,
796575.641547725 1889030.1450377))',-1))
then :
SELECT gid, st_area(the_geom), astext(centroid(the_geom)), isvalid(the_geom)
FROM bug
returns:
1; 0.0001220703125;"GEOMETRYCOLLECTION EMPTY";t
2; 0.0001220703125;"POINT(796578.255471513 1889027.53111391)";t
Fred.
On Wed, Dec 10, 2008 at 9:06 AM, Ghislain Geniaux
<geniaux at avignon.inra.fr>wrote:
> Exact,
>  that's the problem :
> scot3=# SELECT gid, the_geom
> scot3-# FROM bd_dispo_final
> scot3-# WHERE isempty(centroid(the_geom));
>  gid  |
>         the_geom
>  16435 |
> (1 row)
> Here, you will find  the ouput of  pg_dump to study this geometrry. Thanks
> again.
> -- PostgreSQL database dump
> SET client_encoding = 'SQL_ASCII';
> SET standard_conforming_strings = off;
> SET check_function_bodies = false;
> SET client_min_messages = warning;
> SET escape_string_warning = off;
> SET search_path = public, pg_catalog;
> SET default_tablespace = '';
> SET default_with_oids = false;
> -- Name: bug; Type: TABLE; Schema: public; Owner: postgres; Tablespace:--
> CREATE TABLE bug (
>    gid integer,
>    the_geom geometry
> ALTER TABLE public.bug OWNER TO postgres;
> -- Data for Name: bug; Type: TABLE DATA; Schema: public; Owner: postgres
> COPY bug (gid, the_geom) FROM stdin;
> 16435
> -- PostgreSQL database dump complete
> Le 9 déc. 08 à 13:04, Obe, Regina a écrit :
>> Ghislain,
>> The only time I have seen this kind of behavior is when centroid returns
>> an empty geometry collection.  In those cases its because the geometry is
>> invalid.
>> Although none of your geometries are invalid, it could be a bug in either
>> the centroid code or isvalid check that may or may not be fixed in 3.0.3+ of
>> GEOS.
>> Can you do the following
>> FROM ZS2C
>> and send us as an attatched file with one of those geometries.  We can
>> cross check with GEOS 3.0.3 or 3.1 to see if the issue still remains.
>> Thanks,
>> Regina
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-
>> users-bounces at postgis.refractions.net] On Behalf Of Ghislain Geniaux
>> Sent: Monday, December 08, 2008 1:29 PM
>> To: PostGIS Users Discussion
>> Subject: Re: [postgis-users] how to identify the_geom that
>> On Linux  :
>> POSTGIS="1.3.1" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
>> 2007" USE_STATS
>> (1 row)
>> On Macos
>>  POSTGIS="1.2.1" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
>> 2007" USE_STATS
>> (1 row)
>> same result with the two platform and postgis version.
>> Thanks.
>> Le 8 déc. 08 à 17:53, Paragon Corporation a écrit :
>>  What does
>>> SELECT postgis_full_version();
>>> Return
>>> Thanks,
>>> Regina
>>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>>> Ghislain
>>> Geniaux
>>> Sent: Monday, December 08, 2008 11:03 AM
>>> Subject: Re: [postgis-users] how to identify the_geom that cause
>>> I've no collection. It's looks like a bug.
>>> Moreover my table is very large wiht more than 500 000 geometry and i
>>> found no solution to identy the wrong geom.
>>> Here you can see the query, with the same result on different
>>> plateform (LINUX DEBIAN, MACOS, with GEOS 3)
>>> otm=# select distinct geometrytype(the_geom) from ZS2c;
>>>  geometrytype
>>>  MULTIPOLYGON
>>> (1 row)
>>> otm=# select distinct geometrytype(the_geom) from bd_dispo_finalc ;
>>>  geometrytype
>>>  MULTIPOLYGON
>>>  POLYGON
>>> (2 rows)
>>> otm=# create table info_nonvoue1 as
>>> otm-# select b.id_parc, z.niv from bd_dispo_finalc as b, ZS2c as z
>>> otm-# where z.niv=1 and intersects(centroid(b.the_geom),z.the_geom)
>>> and b.the_geom && z.the_geom and isvalid(b.the_geom) and isvalid
>>> (z.the_geom);
>>> ERROR:  Relate Operation called with a LWGEOMCOLLECTION type.  This
>>> is unsupported
>>> otm=#
>>> Le 8 déc. 08 à 13:32, Obe, Regina a écrit :
>>>  Many of the GEOS relation functions do not work with collections.
>>>> You must have a geometry collection in there somewhere or its a bug.
>>>> Also which relation function were you trying?
>>>> To figure out the type of your geometries, run
>>>> SELECT *
>>>> FROM sometable
>>>> WHERE GeometryType(the_geom) = 'GEOMETRYCOLLECTION'
>>>> Nicolas Ribot
>>>> Sent: Monday, December 08, 2008 6:22 AM
>>>> Subject: Re: [postgis-users] how to identify the_geom that cause :
>>>>  I have an error with some geometry that cause : "ERROR Relate
>>>> Operation
>>>>> called withLWGEOMCOLLECTION type".
>>>>> All the geometries seem clean (valid, non empty, closed, only
>>>>> POLYGON,
>>>>> My question : how to get information of which geometry cause the
>>>> problem ?
>>>>> Is there a way  to have information about the geometry during
>>>>> postgis
>>>> is
>>>>> working on a  SQL query ?
>>>>> Thanks.
>>>> Hi Ghislain,
>>>> What the query that failed looks like ?
>>>> The message is telling that one geometry has an invalid type.
>>>> In your query, you could try to ask for ST_GeometryType(geometry) and
>>>> a geometry identifier to see which geometry has the wrong type.
>>>> If you perform a spatial operation, it is possible that
>>>> geometryCollection is produced.
>>>> You could maybe split your query into smaller block to see where such
>>>> collections are generated.
>>>> Nicolas
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> The substance of this message, including any attachments, may be
>>>> confidential, legally privileged and/or exempt from disclosure
>>>> pursuant to Massachusetts law. It is intended
>>>> solely for the addressee. If you received this in error, please
>>>> contact the sender and delete the material from any computer.
>>> Geniaux Ghislain
>>> INRA SAD Ecodéveloppement
>>> Site Agroparc
>>> Domaine St Paul
>>> 84914 Avignon Cedex 9
>>> Tél : 04 32 72 25 64
>>> Fax : 04 32 72 25 62
>> Geniaux Ghislain
>> Site Agroparc
>> Domaine St Paul
> Geniaux Ghislain
> Site Agroparc
> Domaine St Paul
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081210/6dfcfd02/attachment.html>
