[postgis-users] Re: if i use postgis, is it true that i'll then have to worry about supporting only 1 database??
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Fri Feb 8 08:53:20 PST 2008
"So, if you think direct editing of SDO_GEOMETRY from ArcGIS (a) works
and (b) works well then perhaps you have a case to believe that direct
editing of PostGIS is on the way too."
AFAIK: the answer to a) and b) is both no. You'll always need SDE in
between., if you use SDO_GEOMETRY.
I would love to be proven wrong though in this case :-)
Best regards,
Bart
Paul Ramsey schreef:
> On 8-Feb-08, at 1:39 AM, dnrg wrote:
>> ESRI tells me that, at the ArcGIS Desktop release 9.3,
>> you'll be able to edit PostGIS data as core
>> functionality. No SDE required. This will open doors
>> and minds I hope. Paul, any comments on that?
> I'll believe it when I see it. Different elements of the ESRI
> marketing apparatus are interpreting the "support PostGIS"
> announcement differently. The most believable story I have heard is
> that ArcServer (nee SDE) will support a PostGIS geometry type, in much
> the same way as it support the Oracle SDO_GEOMETRY type.  So, if you
> think direct editing of SDO_GEOMETRY from ArcGIS (a) works and (b)
> works well then perhaps you have a case to believe that direct editing
>> Paul, will PostGIS ever have versioning functionality
>> for editing workflows similar to ArcSDE? Guess that
>> would pervert the data, and then PostGIS would "own"
>> the data in a way like ArcSDE does presently. Still,
>> many shops find versioning valuable for workflows.
> Database lock-in is a fact of life, simple because it is hard to
> migrate databases, no matter how open they are. The best versioning
> solution I have seen is the Oracle implementation, which does
> "workspaces" using the basic MVCC versioning information available
> per-tuple.  I would love to have that, but frankly it requires a lot
> of core PostgreSQL back-end work, and the PgSQL core team doesn't have
> workspaces as a high (or even low) priority item.
> If we built a versioning system ala ESRI (side tables and references),
> we could do a somewhat better job, because it would be in the database
> level, not the middle-ware. However, it would have the same
> limitations in terms of requiring client software that knew what the
> heck to do with the stuff.
> "Why not."  Explain your use cases that cannot be met any other way.
> There are some, but they are dwarfed by other use cases that have
> higher priority, in my opinion.  I see way more people using PostGIS
> for geoprocessing, for example, so a more robust and faster overlay
> facility seems like an important thing.  Ditto for more core geodetic
> support.
> P.
> postgis-users mailing list
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
