[postgis-users] Trigger Function for Updating Geom
Willem Buitendyk willem at pcfish.ca
Wed Jan 23 01:19:44 PST 2008
What you revised makes more sense;  however, the problem now is that the
geom column does not update at all.  I modified the function to include
RETURN NEW;
CREATE or replace FUNCTION make_geom () RETURNS trigger as
$BODY$
BEGIN
NEW.hydgeom = GeometryFromText('POINT (' || cast(NEW.longitude as
varchar(10)) || ' ' || cast(NEW.latitude as varchar(10)) || ')', 8307);
RETURN NEW;
END
$BODY$
LANGUAGE plpgsql;
CREATE TRIGGER make_geom_trigger AFTER INSERT OR UPDATE ON hyd FOR EACH
ROW EXECUTE PROCEDURE make_geom();
Any ideas?
Cheers
Bruce Rindahl wrote:
> Try:
> $BODY$
> BEGIN
> END
> $BODY$
> LANGUAGE plpgsql;
> This will update each row as it is processed.  What you were doing was
> trying to update EVERY row as EACH one was processed.
> Bruce Rindahl
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Willem
> Buitendyk
> Sent: Tuesday, January 22, 2008 2:17 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Trigger Function for Updating Geom
> Hi there,
> I am trying to figure out how to go about creating a trigger that
> updates the geom on each insert.  Currently, I am using the following
> update statement on the table after bulk loading data in:
> update temp_hyd set hydgeom = GeometryFromText('POINT (' ||
> cast(longitude as varchar(10)) || ' ' || cast(latitude as varchar(10))
> || ')', 8307);
> I admit to feeling a little lost as I am only now just starting to
> migrate GIS data into a server.  So using relational databases are a
> little new to me (and I don't think Access counts).  I am hoping that only
> updating those newly inserted records will be a whole lot faster then
> redoing the whole table.
> Here is what I have so far:
> $BODY$
> BEGIN
> update hyd set hydgeom = GeometryFromText('POINT (' || cast(longitude as
> varchar(10)) || ' ' || cast(latitude as varchar(10)) || ')', 8307);
> END
> $BODY$
> LANGUAGE plpgsql;
> And of course it doesn't work.  I get the following after doing an
> insert statement:
> ERROR: stack depth limit exceeded
> SQL state: 54001
> Hint: Increase the configuration parameter "max_stack_depth", after
> ensuring the platform's stack depth limit is adequate.
> Context: SQL statement "update hyd set hydgeom = GeometryFromText('POINT
> (' || cast(longitude as varchar(10)) || ' ' || cast(latitude as
> varchar(10)) || ')', 8307)"
> Appreciate any help with this,
> Willem
> postgis-users mailing list
