[postgis-users] Trigger Function for Updating Geom
    Obe, Regina
    robe.dnd at cityofboston.gov
    Wed Jan 23 04:23:00 PST 2008
It should be
NEW.hydgeom :=
You have an = there (which would evaluate to a boolean of some sort)
instead of plpgsql assignment :=
Also I think using makepoint is more efficient,shorter to write, and
easier to read
So would be
CREATE or replace FUNCTION make_geom () RETURNS trigger as
$BODY$
BEGIN
NEW.hydgeom := SetSRID(makepoint(NEW.longitude, NEW.latitude), 8307);
RETURN NEW;
END
$BODY$
LANGUAGE plpgsql;
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Willem Buitendyk
Sent: Wednesday, January 23, 2008 4:20 AM
To: rindahl at lrcwe.com; PostGIS Users Discussion
Subject: Re: [postgis-users] Trigger Function for Updating Geom
What you revised makes more sense;  however, the problem now is that the
geom column does not update at all.  I modified the function to include
RETURN NEW;
$BODY$
BEGIN
NEW.hydgeom = GeometryFromText('POINT (' || cast(NEW.longitude as
varchar(10)) || ' ' || cast(NEW.latitude as varchar(10)) || ')', 8307);
RETURN NEW;
END
$BODY$
LANGUAGE plpgsql;
CREATE TRIGGER make_geom_trigger AFTER INSERT OR UPDATE ON hyd FOR EACH
ROW EXECUTE PROCEDURE make_geom();
Any ideas?
Cheers
Bruce Rindahl wrote:
> Try:
> $BODY$
> BEGIN
8307);
> END
> $BODY$
> LANGUAGE plpgsql;
> This will update each row as it is processed.  What you were doing was
> trying to update EVERY row as EACH one was processed.
> Bruce Rindahl
Willem
> Buitendyk
> Sent: Tuesday, January 22, 2008 2:17 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Trigger Function for Updating Geom
> Hi there,
> I am trying to figure out how to go about creating a trigger that
> updates the geom on each insert.  Currently, I am using the following
> update statement on the table after bulk loading data in:
> update temp_hyd set hydgeom = GeometryFromText('POINT (' ||
> cast(longitude as varchar(10)) || ' ' || cast(latitude as varchar(10))
> || ')', 8307);
> I admit to feeling a little lost as I am only now just starting to
> migrate GIS data into a server.  So using relational databases are a
> little new to me (and I don't think Access counts).  I am hoping that
only
> updating those newly inserted records will be a whole lot faster then
> redoing the whole table.
> Here is what I have so far:
> $BODY$
> BEGIN
> update hyd set hydgeom = GeometryFromText('POINT (' || cast(longitude
as
> varchar(10)) || ' ' || cast(latitude as varchar(10)) || ')', 8307);
> END
> $BODY$
> LANGUAGE plpgsql;
EACH
> And of course it doesn't work.  I get the following after doing an
> insert statement:
> ERROR: stack depth limit exceeded
> SQL state: 54001
> Hint: Increase the configuration parameter "max_stack_depth", after
> ensuring the platform's stack depth limit is adequate.
> Context: SQL statement "update hyd set hydgeom =
> (' || cast(longitude as varchar(10)) || ' ' || cast(latitude as
> varchar(10)) || ')', 8307)"
> Appreciate any help with this,
> Willem
> postgis-users mailing list
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
