[postgis-users] Testing for empty feature
Martin Davis mbdavis at refractions.net
Fri Jul 4 09:03:33 PDT 2008
Actually JTS/GEOS handle empty MultiPolygons just fine. I don't know why
the MULTIPOLYGON EMPTY is being converted to a general
GeometryCollection - I think this must be something that is being done
by PostGIS.
Seems like the answer is to use ST_IsEmpty. Doing text comparisons is
always going to be risky.
Kevin Neufeld wrote:
> I believe that an empty multipolygon is converted into an empty
> geometrycollection in JTS and hence PostGIS.
> postgis=# SELECT ST_AsText('MULTIPOLYGON EMPTY'::geometry);
>         st_astext
>  GEOMETRYCOLLECTION EMPTY
> (1 row)
> postgis=# SELECT ST_IsEmpty('MULTIPOLYGON EMPTY'::geometry);
>  st_isempty
>  t
> (1 row)
> Alternatively, I suppose you could get the number of points in the geometry.
> postgis=# SELECT ST_NPoints('MULTIPOLYGON EMPTY'::geometry);
>  st_npoints
>           0
> (1 row)
> Cheers,
> Kevin
> Sean Fulton wrote:
>> How do I test for an empty feature such as 'MULTIPOLYGON(( EMPTY ))' ?
>> IsEmpty seems to work only for collections.
>> astext(wkb_geometry) = 'MULTIPOLYGON(( EMPTY ))' doesn't seem to work.
>> Thanks,
>>     Sean
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
